- Hardware & Machines
- Computers and Hardware
- Results of latency test, list of computers tested for use with LinuxCNC
- BeagleBrainz
- Visitor
31 Oct 2020 00:51 - 31 Oct 2020 00:53 #187853
by BeagleBrainz
Replied by BeagleBrainz on topic Results of latency test, list of computers tested for use with LinuxCNC
Just out of interest why is the --nobase & --base options being used ?
Can anyone explain the binsize parameter.
It does seem to affect latency, but which size 0.1us or 1.0us gives a result that matches real world use ?
For instance, althouhg short test there was a difference seen:
Binsize as per script:
Binsize as a default when running just with the base switch:
Last edit: 31 Oct 2020 00:53 by BeagleBrainz.
- seuchato
- Thank you received: 126
31 Oct 2020 06:48 - 31 Oct 2020 06:51 #187860
by seuchato
Replied by seuchato on topic Results of latency test, list of computers tested for use with LinuxCNC
@my1987toyota
Do you need pcspkr and sound modules? If not, disable them in bios or block the kernel modules to be loaded. Depending on what PC, I usually get much better latency, if these modules are not loaded.
Last edit: 31 Oct 2020 06:51 by seuchato.
The following user(s) said Thank You: my1987toyota
- seuchato
31 Oct 2020 06:52 #187861
by seuchato
@BeagleBrainz
"latency-histogram --nobase --base 25000 --sbinsize 1000 --nox"
This is a bug in the script. I'll change that. Thanks for getting this pointed out.
Greez
chris
Greez
chris
- seuchato
31 Oct 2020 06:58 #187862
by seuchato
The two tests do show very similar data (given the test ran only for 7/8 secs), but the x-scale of the plot differ by a factor of 10. And that's exactly controlled by binsize: resolution of the diagram in x-axis.
hth
chris
hth
chris
- my1987toyota
- Thank you received: 448
01 Nov 2020 02:47 - 01 Nov 2020 03:01 #187963
by my1987toyota
I will try your suggestion in my future tests
for now though I have a test with linux mint19.3 with Preempt on my PnP project computer previously using Debian Wheezy 2.7.14 RTAI
unfortunately it doesn't show core temps ( perhaps too old of a processor )
This is of a Lenovo Think Center 2010 vintage
as you can see without the core temp it won't finish it's report.
with Linux Mint 19.3 XFCE it's not suitable for Linuxcnc ( huge understatment )
Next- Debian Buster and see how it does with that.
Replied by my1987toyota on topic Results of latency test, list of computers tested for use with LinuxCNC
@my1987toyota
LinuxCNC pc tests, version 20200930, started 31.10.2020 19:48:39
General info:
LENOVO, H215
Bios version D2KT25BUS, dated 08/18/2010
Chipset: Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name : AMD Athlon(tm) II X2 250 Processor
cpu cores : 2
stepping : 3
cache size : 1024 KB
RAM related data:
Maximum Capacity: 8 GB
Size: No Module Installed
GPU related data:
product: RS780L [Radeon 3000]
configuration: driver=radeon latency=0
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Linux Mint 19.3"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency
Desktop environment : lightdm
Windowmanager : Xfwm4
Displaymanager : lightdm
Kernel related data:
Kernel 5.0.0-32-generic
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Cpu idle driver: none
Kernel modules data:
Check if pcspkr is loaded: [0;32mNo, which is good![0m
Check if snd modules are loaded: [0;31mYes, may cause bigger latency.[0m
can probably be disabled in bios, alternatively, you can run
"./block-snd-modules"
which has just now been created for your convenience.
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : PixArt USB Optical Mouse
Mice attached to USB:
Keyboards attached to USB:
LinuxCNC related data:
LinuxCNC version is: 2.8.0.96.g589db060d
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://vimeo.com/150574260', WID 60817513
Command for latency test is:
su cnc001 -c "latency-histogram --nobase --base 25000 --sbinsize 1000 --nox 2>&1 | tee -a 1604188058.lat &"
Latency testing loop started Sat Oct 31 19:48:54 EDT 2020,
should end after Sat Oct 31 21:48:54 EDT 2020
Swap useage: prerun: 0, running: 0
CPU core temperatures:Note: Using POSIX non-realtime
0 secs servo min:-996.100 uS max:1250.100 uS sdev: 12.000 uS
1 secs servo min:-997.600 uS max:1462.400 uS sdev: 9.200 uS
2 secs servo min:-997.600 uS max:1462.400 uS sdev: 8.100 uS
3 secs servo min:-998.300 uS max:1462.400 uS sdev: 8.600 uS
4 secs servo min:-999.800 uS max:2151.400 uS sdev: 8.500 uS
5 secs servo min:-999.800 uS max:5366.700 uS sdev: 8.300 uS
6 secs servo min:-999.800 uS max:9617.200 uS sdev: 8.500 uS
8 secs servo min:-999.800 uS max:9617.200 uS sdev: 8.900 uS
9 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.000 uS
10 secs servo min:-999.800 uS max:9617.200 uS sdev: 8.900 uS
11 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.000 uS
11 secs servo min:-999.800 uS max:9617.200 uS sdev: 8.700 uS
13 secs servo min:-999.800 uS max:9617.200 uS sdev: 8.800 uS
14 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
14 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
15 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
16 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
17 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
18 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
19 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
20 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
21 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
22 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
23 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
24 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
25 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
26 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
27 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
29 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
30 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
30 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
31 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
32 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
33 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
34 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
35 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
36 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
37 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
38 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
39 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
40 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
41 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
42 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
43 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
44 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
45 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
46 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
46 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.200 uS
47 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
48 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
49 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.200 uS
50 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
51 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
52 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
53 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
54 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
55 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
56 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
57 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
58 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
59 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
60 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
61 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
62 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
63 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
64 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
65 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
66 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
67 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
68 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
69 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
70 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
71 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
72 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
73 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
74 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
75 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
76 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
77 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
78 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
79 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
80 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
81 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
82 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
83 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
84 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
86 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
87 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
88 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
89 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
90 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
91 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
92 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
93 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
94 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
95 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
96 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
97 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
98 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
99 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
100 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
102 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
103 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
104 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
105 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
107 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
108 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
109 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
110 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
111 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
112 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
113 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
114 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
115 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
115 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
117 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
118 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
119 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
120 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
121 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
122 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
123 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
124 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
125 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
126 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
127 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
129 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
130 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
131 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
132 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
133 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
134 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
135 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
136 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
137 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
138 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
139 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
140 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
141 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
142 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
144 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
145 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
147 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
148 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
149 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
150 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
151 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
152 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
153 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
155 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
156 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
157 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
158 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
159 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
160 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
161 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
162 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
164 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
165 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
167 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
169 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
170 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
171 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
172 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
173 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
174 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
175 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
177 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
178 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
179 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
180 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
181 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
182 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
183 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
184 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
185 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
186 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
187 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
188 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
189 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
190 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
191 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
192 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
193 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
194 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
195 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
197 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
198 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
199 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
200 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
201 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
202 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
203 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
204 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
205 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
206 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
207 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
208 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
209 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
210 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
211 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
212 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
213 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
214 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
215 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
216 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
217 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.200 uS
219 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
220 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.200 uS
221 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
222 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.200 uS
223 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
224 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
226 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
227 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
228 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
229 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
230 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
231 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
232 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
233 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.200 uS
234 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.200 uS
235 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
236 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
237 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
238 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
239 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
241 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
242 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
243 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
245 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
247 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
248 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
249 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
250 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
251 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
252 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
253 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
254 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
256 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
257 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
258 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
259 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
260 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
261 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
262 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
263 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
264 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
265 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
266 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
267 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
269 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
270 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
272 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
273 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
274 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
275 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
276 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
277 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
279 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
281 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
283 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
284 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
285 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
286 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
287 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
288 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
289 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
290 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
292 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
293 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
294 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
295 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
296 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
297 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
298 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
299 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
300 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
301 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
302 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
303 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
304 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
305 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
306 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
307 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
308 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
309 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
310 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
311 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
312 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
313 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
314 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
315 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
316 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
317 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
318 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
319 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
320 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
321 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
322 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
323 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
324 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
325 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
326 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
328 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
329 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
330 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
331 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
332 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
333 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
334 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
335 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
336 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
337 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
338 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
339 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
340 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
341 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
342 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
343 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
344 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
345 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
346 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
347 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
348 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
349 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
350 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
351 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
352 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
353 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
354 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
355 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
356 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
357 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
358 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
360 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
361 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
362 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
363 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
364 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
365 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
366 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
367 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
368 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
369 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
370 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
371 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
372 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
373 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
374 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
375 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
376 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
377 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
378 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS
379 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
380 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
381 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
382 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
383 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
384 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
385 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
386 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
387 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
388 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
389 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
390 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
391 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
392 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
393 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
394 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
395 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
396 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
397 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
398 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
399 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
400 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
401 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
402 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
403 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
404 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
405 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
407 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
408 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
409 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
410 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
412 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
413 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
415 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
416 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
417 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
418 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
419 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
420 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
421 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
422 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
423 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
424 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
425 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
426 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
427 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
428 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
429 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
430 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
431 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
432 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
433 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
434 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
435 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
436 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
437 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
438 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
439 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
440 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
441 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
442 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
443 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
444 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
445 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
446 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
447 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
448 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
449 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
450 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
451 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
452 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
453 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
454 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS
455 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
456 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
457 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
458 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
459 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
460 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
461 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
462 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
463 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
464 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
465 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
466 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
467 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
468 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
469 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
470 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
471 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
472 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
473 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
474 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
475 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
477 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
478 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
479 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
480 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
482 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
483 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
485 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
486 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
487 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
489 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
490 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
491 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
492 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
493 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
494 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
495 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
496 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
497 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
498 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
499 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
500 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
502 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
503 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
504 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
505 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
506 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
507 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
508 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
509 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
510 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
511 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
513 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
514 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
516 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
517 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
518 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
519 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
520 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
521 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
522 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
523 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
524 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
525 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
526 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
527 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
528 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
529 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
530 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
531 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
532 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
533 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
534 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
535 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
535 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
536 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
537 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS
538 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
539 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
540 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
541 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
542 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
544 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
545 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
546 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
547 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
548 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
549 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
550 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
551 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
552 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
553 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
554 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
555 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
556 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
557 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
558 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
559 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
560 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
561 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
562 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
563 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
564 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
565 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
566 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
567 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
568 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
569 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
571 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
572 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
573 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
574 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
575 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
576 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
577 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
578 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
579 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
580 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
581 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
582 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
583 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
584 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
585 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
586 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
587 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
588 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
589 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
590 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
591 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
593 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
594 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
595 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
596 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
597 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
598 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
599 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
600 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
602 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
603 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
604 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
605 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
606 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS
607 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
608 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
609 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
610 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
611 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
612 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
613 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
614 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
615 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
616 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
617 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
618 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
619 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
620 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
621 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
623 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
624 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
625 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
626 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
627 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
628 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
629 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
630 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
631 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
632 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
633 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
634 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
635 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
636 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
637 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
638 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
639 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
640 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
641 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
642 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
643 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
644 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
645 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
646 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
647 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
648 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
649 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
650 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
651 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
652 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
653 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
654 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
655 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
656 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
657 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
658 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
659 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
660 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
661 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
662 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
663 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
664 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
665 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
666 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
667 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
668 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
669 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
670 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
671 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
672 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
673 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
674 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
675 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
676 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
677 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
678 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
679 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
680 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
681 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
682 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
683 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
684 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
685 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
687 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
689 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
690 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
691 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS
692 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
693 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
694 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
695 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
696 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
697 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
698 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
699 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
700 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
701 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
702 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
703 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
704 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
705 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
706 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
707 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
708 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
709 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
710 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
711 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
713 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
714 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
715 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
716 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
717 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
718 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
719 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
720 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
721 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
722 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
723 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
724 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
725 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
726 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
727 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
728 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
729 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
730 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
731 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
732 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
733 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
734 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
735 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
736 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
737 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
738 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
739 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
740 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
741 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
742 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
743 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
744 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
745 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
746 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
747 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
748 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
749 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
750 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
751 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
752 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
753 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
754 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
755 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
756 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
757 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
758 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
759 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
760 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
761 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
762 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
763 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
764 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
765 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
766 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
767 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
768 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
770 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
771 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
772 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
773 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
774 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
775 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
776 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
777 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
778 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
779 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
780 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
781 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
782 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
783 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
784 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
785 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
786 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
787 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
788 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
789 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
791 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
792 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
793 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
794 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
795 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
796 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
797 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
798 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
799 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
800 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
801 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
802 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
803 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
804 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
805 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
806 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
807 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
808 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
809 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
810 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
812 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
813 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
814 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
815 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
816 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
817 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
818 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
819 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
820 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
821 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
822 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
823 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
824 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
825 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
826 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
828 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
829 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
830 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
831 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
832 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
833 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
834 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
835 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
836 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
837 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
838 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
839 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
840 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
841 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
842 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
844 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
845 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
846 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
847 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
848 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
849 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
850 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
851 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
852 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
853 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
854 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
855 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
856 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
857 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
858 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
859 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
860 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
861 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
862 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
863 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
864 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
865 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
866 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
867 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
868 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
869 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
870 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
871 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
872 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
873 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
873 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
875 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
876 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
877 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
878 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
879 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
880 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
881 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS
882 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
883 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
884 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
886 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
887 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
888 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
889 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
890 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
891 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
892 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
893 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
894 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
895 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
896 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
897 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
898 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
899 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
900 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
901 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
902 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
903 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
904 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
905 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
906 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
907 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
908 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
909 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
910 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
911 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
912 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
913 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
914 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
915 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
916 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
917 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
918 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
919 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
920 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
922 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
923 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
924 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
925 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
926 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
928 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
929 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
931 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
932 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
933 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
934 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
935 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
936 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
937 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
938 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
939 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
940 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
941 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
942 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
944 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
945 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
946 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
947 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
948 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
949 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
950 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
951 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
952 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
953 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
954 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
955 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
957 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
958 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
960 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
961 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
962 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
963 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
965 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
966 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
967 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
968 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
969 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
970 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
971 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
972 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
973 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
974 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
975 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
976 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
977 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
978 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
979 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
980 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
981 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
982 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
983 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
984 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
985 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
986 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
987 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
988 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
989 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
990 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
991 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
992 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
993 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
994 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
995 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
996 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
997 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
998 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
999 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1000 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1001 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1002 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1003 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1004 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1005 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1006 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1007 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1008 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1009 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1010 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1011 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1012 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1013 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1014 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1015 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1016 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1017 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1018 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1019 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1020 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1021 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1022 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1024 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1025 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1026 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1028 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1029 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1030 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1031 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1032 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1033 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1034 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1035 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1036 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1037 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1038 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1039 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1040 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1041 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1042 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1043 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1044 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1045 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1046 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1047 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1048 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1049 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1050 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1051 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1052 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1053 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1054 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1055 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1056 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1057 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1058 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1059 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1060 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1061 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1062 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1063 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1064 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1065 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1066 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1067 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1068 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1069 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1070 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1071 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1072 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1073 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1074 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1075 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1076 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1077 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1078 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1079 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1080 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1081 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1082 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1083 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1085 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1086 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1087 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1088 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1090 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1091 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1092 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1093 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1094 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1095 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1096 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1097 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1098 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1099 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1100 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1101 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1102 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1103 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1104 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1105 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1106 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1107 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1108 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1109 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1110 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1112 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1113 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1115 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1116 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1117 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1118 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1119 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1120 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1121 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1122 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1123 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1124 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1125 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1126 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1127 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1128 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1129 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1130 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1131 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1132 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1133 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1134 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1135 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1136 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1137 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1138 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1139 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1140 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1141 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1142 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1143 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1144 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1145 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1146 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1147 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1148 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1149 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1150 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1151 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1153 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1154 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1155 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1156 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1157 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1158 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1159 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1160 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1161 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1162 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1163 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1164 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1165 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1166 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1168 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1170 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1171 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1172 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1174 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1175 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1176 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1177 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1178 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1179 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1180 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1182 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1184 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1185 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1186 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1187 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1188 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1190 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1191 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1193 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1194 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1195 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1196 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1198 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1199 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1200 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1201 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1202 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1203 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1204 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1206 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1207 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1208 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1209 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1210 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1211 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS
1212 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1213 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1214 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1215 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1216 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1217 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1218 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1219 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1220 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1221 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1222 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1223 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1224 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1225 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1226 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1227 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1228 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1229 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1230 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1231 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1232 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1234 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1235 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1236 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1238 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1239 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1240 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1241 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1242 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1243 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1244 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1245 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1246 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1247 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1248 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1249 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1250 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1251 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1252 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1253 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1254 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1255 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1257 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1258 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1259 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1260 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1262 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1263 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1264 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1265 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1266 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1267 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1268 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1269 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1270 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1271 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1272 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1273 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1274 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1275 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1276 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1278 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1280 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1281 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1283 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1284 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1285 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1286 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1287 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1288 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1289 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1290 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1291 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1292 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1293 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1294 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1296 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1297 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1298 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1299 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1300 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1301 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1302 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1304 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1305 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1306 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1307 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1308 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1309 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1310 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1311 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1312 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1313 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1314 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1315 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1316 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1318 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1319 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1320 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1322 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1323 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1324 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1325 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1326 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1327 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1328 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1329 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1330 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1331 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1332 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1333 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1334 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1335 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1336 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1337 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1338 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1339 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1340 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1341 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1342 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1343 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1344 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1345 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1346 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1347 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1348 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1349 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1350 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1351 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1352 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1353 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1354 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1355 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1356 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1357 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1358 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1359 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1360 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1361 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1362 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1363 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1364 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1365 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1366 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1367 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1368 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1369 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1370 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1371 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1372 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1373 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1374 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1375 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1376 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1377 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1378 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1379 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1380 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1381 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1382 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1383 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1384 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1385 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1386 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1387 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1388 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1389 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1390 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1391 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1392 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1393 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1394 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1395 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1396 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1398 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1399 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1401 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1402 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1403 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1404 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1405 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1406 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1407 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1408 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1409 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1410 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1411 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1412 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1413 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1414 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1415 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1416 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1418 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1419 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1420 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1421 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1422 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1423 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1424 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1425 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1426 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1427 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1428 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1429 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1430 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1432 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1433 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1434 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1435 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1436 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1438 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1440 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1441 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1442 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1443 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1444 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1445 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1446 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1447 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1448 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1449 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1450 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1451 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1452 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1453 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1454 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1455 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1456 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1457 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1458 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1459 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1460 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1461 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1462 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1463 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1464 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1465 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1466 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1467 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1468 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1469 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1470 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1471 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1472 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1473 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1474 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1475 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1476 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1477 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1479 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1480 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1481 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1482 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1483 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1484 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1485 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1486 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1488 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1489 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1490 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1491 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1492 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1493 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1494 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1495 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1496 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1497 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1498 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1499 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1500 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1501 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1502 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1503 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1505 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1507 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1509 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1511 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1512 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1513 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1514 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1515 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1516 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1517 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1519 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1520 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1521 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1522 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1523 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1524 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1525 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1526 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1527 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1529 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1530 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1532 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1533 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1534 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1535 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1536 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1537 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1538 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1539 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1540 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1541 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1542 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1543 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1544 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1545 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1546 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1547 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1549 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1550 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1551 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1552 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1553 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1554 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1555 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1556 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1557 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1558 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1559 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1560 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1561 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1563 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1564 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1566 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1567 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1568 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1569 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1570 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1571 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1572 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1574 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1575 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1576 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1577 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1578 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1579 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1580 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1581 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1582 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1583 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1584 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1585 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1586 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1587 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1588 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1589 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1591 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1592 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1593 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1594 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1595 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1596 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1597 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1598 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1599 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1600 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1601 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1602 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1603 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1604 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1605 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1606 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1607 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1608 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1609 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1610 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1611 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1612 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1614 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1615 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1616 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1617 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1618 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1619 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1620 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1621 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1622 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1623 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1624 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1625 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1626 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1627 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1628 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1629 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1630 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1631 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1632 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1633 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1634 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1635 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1636 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1637 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1638 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1639 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1640 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1641 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1642 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1643 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1644 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1645 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1646 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1647 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1648 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1649 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1650 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1651 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1652 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1653 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1654 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1655 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1656 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1657 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1658 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1659 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1660 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1661 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1662 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1663 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1665 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1666 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1667 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1668 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1669 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1670 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1671 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1672 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1673 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1674 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1675 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1676 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1677 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1678 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1679 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1680 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1681 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1682 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1683 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1684 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1685 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1686 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1687 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1688 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1689 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1690 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1691 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1692 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1692 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1693 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1694 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1695 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1696 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1697 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1698 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1699 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1700 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1701 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1702 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1703 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1704 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1705 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1706 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1707 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1708 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1709 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1710 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1711 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1713 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1714 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1715 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1716 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1717 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1718 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1719 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1721 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1722 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS
1723 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1725 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1726 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1727 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1729 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1730 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1731 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1732 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1733 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1734 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1735 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1736 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1737 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1738 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1739 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1740 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1741 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1742 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1743 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1744 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1745 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1746 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1747 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1748 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1749 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1750 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1751 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1752 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1753 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1754 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1755 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1756 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1757 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1758 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1760 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1761 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1762 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1763 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1764 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1766 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1768 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1769 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1770 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1771 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1772 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1773 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1774 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1775 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1776 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1778 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1779 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1780 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1781 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1782 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1783 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1784 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1785 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1786 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1787 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1789 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1790 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1791 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1792 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1793 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1794 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1795 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1796 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1797 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1798 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1799 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1800 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1801 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1802 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1803 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1804 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1805 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1806 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1807 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1808 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1809 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1810 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1811 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1812 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1813 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1814 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1815 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1816 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1817 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1818 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1819 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1820 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1821 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1822 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1823 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1824 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1825 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1826 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1827 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1828 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1829 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1830 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1831 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1832 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1833 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1834 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1835 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1836 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1837 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1839 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1841 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1842 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1843 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1844 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1845 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1846 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1847 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1848 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1849 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1850 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1851 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1852 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1853 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1854 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1855 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1856 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1857 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1858 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1859 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1860 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1861 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1862 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1863 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1864 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1865 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1866 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1867 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1868 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1869 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1870 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1871 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1872 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1873 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1874 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1875 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1876 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1877 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1878 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1880 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1881 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1882 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1883 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1885 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1886 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1887 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1889 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1890 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1891 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1892 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1893 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1894 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1895 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1896 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1897 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1898 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1899 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1900 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1902 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1903 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1904 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1905 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1906 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1907 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1908 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1909 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1910 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1911 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1912 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1913 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1914 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1915 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1916 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1917 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1918 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1919 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1920 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1921 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1922 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1923 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1924 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1925 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1926 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1927 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1928 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1929 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1930 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1931 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1932 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1934 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1935 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1936 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1937 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1938 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1939 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1940 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1941 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1942 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1943 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1944 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1945 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1947 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1949 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1950 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1951 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1952 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1953 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1954 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1955 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1956 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1957 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1958 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1959 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1960 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1961 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1962 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1963 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1964 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1965 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1966 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1967 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1968 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1969 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1970 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1972 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1973 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1974 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1975 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1976 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1977 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1978 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1979 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1980 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1981 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1982 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1984 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1985 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1986 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1987 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1988 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1989 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1991 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1993 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1994 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1995 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1996 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1997 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1998 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
1999 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2000 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2001 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2002 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2003 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2005 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2007 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2008 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2010 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2011 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2012 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2013 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2015 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2016 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2017 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2018 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2019 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2020 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2021 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2022 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2023 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2024 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2026 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2027 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2028 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2029 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2030 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2031 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2032 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2033 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2034 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2035 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2036 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2037 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2038 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2039 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2041 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2042 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2043 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2044 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2045 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2046 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2047 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2048 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2049 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2050 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2051 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2052 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2053 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2054 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2055 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2056 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2057 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2058 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2059 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2060 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2061 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2062 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2063 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2064 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2065 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2066 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2067 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2068 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2069 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2070 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2071 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2072 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2074 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2075 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2076 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2077 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2078 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2079 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2080 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2081 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2082 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2083 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2084 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2086 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2087 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2088 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2089 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2090 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2091 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2092 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2094 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2095 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2096 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2097 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2098 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2099 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2100 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2101 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2102 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2103 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2104 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2105 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2106 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2107 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2108 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2109 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2110 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2111 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2112 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2113 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2114 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2115 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2116 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2117 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2118 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2120 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2121 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2122 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2123 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2124 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2125 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2126 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2127 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2128 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2129 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2130 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2132 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2133 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2134 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2135 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2136 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2137 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2138 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2139 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2140 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2141 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2142 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2143 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2144 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2145 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2146 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2147 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2148 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2149 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2150 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2151 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2152 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2153 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2154 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2155 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2156 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2157 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2158 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2159 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2161 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2162 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2163 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2164 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2165 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2167 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2168 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2170 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2171 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2173 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2174 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2175 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2176 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2177 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2178 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2179 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2180 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2182 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2184 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2185 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2186 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2187 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2188 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2190 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2191 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2192 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2193 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2194 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2195 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2196 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2198 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2199 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2200 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2201 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2202 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2203 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2204 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2205 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2206 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2207 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2208 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2209 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2210 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2212 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2213 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2214 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2215 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2216 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2217 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2218 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2219 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2220 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2221 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2222 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2224 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2225 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2226 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2227 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2228 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2229 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2230 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2231 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2232 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2233 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2234 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2236 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2237 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2238 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2239 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2240 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2241 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2242 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2243 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2244 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2246 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2247 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2248 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2249 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2250 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2251 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2252 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2253 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2254 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2255 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2257 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2258 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2259 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2261 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2262 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2263 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2265 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2266 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2267 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2268 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2269 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2270 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2271 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2272 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2273 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2274 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2275 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2276 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2277 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2278 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2279 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2280 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2281 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2282 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2283 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2284 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2285 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2286 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2287 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2288 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2289 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2290 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2291 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2292 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2293 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2294 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2295 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2296 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2297 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2298 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2299 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2300 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2301 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2302 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2303 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2304 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2305 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2306 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2307 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2308 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2309 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2310 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2311 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2313 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2314 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2315 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2316 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2317 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2318 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2319 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2320 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2321 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2322 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2323 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2324 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2326 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2327 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2329 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2330 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2331 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2332 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2333 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2334 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2335 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2336 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2337 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2338 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2339 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2340 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2341 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2342 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2343 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2344 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2345 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2346 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2347 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2348 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2349 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2350 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2351 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2352 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2353 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2354 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2355 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2356 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2357 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2358 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2359 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2360 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2361 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2362 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2363 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2364 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2365 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2367 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2368 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2369 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2371 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2372 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2373 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2374 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2375 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2376 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2377 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2378 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2379 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2380 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2381 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2383 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2384 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2385 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2386 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2388 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2389 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2390 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2391 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2392 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2393 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2394 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2395 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2396 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2397 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2398 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2399 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2400 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2401 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2402 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2403 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2404 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2405 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2406 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2407 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2408 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2409 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2410 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2411 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2412 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2413 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2414 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2415 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2416 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2417 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2418 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2419 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2420 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2421 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2422 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2423 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2424 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2425 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2426 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2427 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2428 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2430 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2431 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2432 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2433 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2434 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2435 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2436 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2437 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2438 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2439 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2440 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2441 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2442 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2443 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2444 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2445 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2446 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2447 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2448 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2449 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2450 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2451 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2452 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2453 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2454 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2455 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2457 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2458 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2459 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2460 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2462 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2463 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2464 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2465 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2466 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2467 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2468 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2469 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2471 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2472 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2473 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2474 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2475 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2476 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2477 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2478 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2479 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2481 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2482 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2483 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2484 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2485 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2486 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2487 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2488 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2489 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2490 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2491 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2492 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2493 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2494 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2495 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2496 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2497 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2498 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2499 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2501 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2502 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2505 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2506 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2507 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2509 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2511 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2512 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2513 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2514 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2515 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2516 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2517 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2518 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2519 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2521 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2522 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2523 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2524 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2525 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2526 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2527 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2528 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2529 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2530 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2531 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2532 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2533 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2534 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2535 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2536 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2537 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2538 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2539 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2540 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2541 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2542 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2543 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2544 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2545 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2546 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2547 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2548 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2549 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2550 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2551 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2552 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2553 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2554 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2555 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2556 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2557 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2558 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2560 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2562 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2563 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2564 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2565 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2566 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2567 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2568 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2569 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2570 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2571 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2572 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2573 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2574 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2575 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2576 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2577 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2578 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2579 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2580 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2581 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2582 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2583 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2584 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2585 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2586 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2587 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2588 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2590 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2591 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2592 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2593 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2594 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2595 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2596 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2597 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2598 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2599 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2600 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2601 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2602 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2603 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2605 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2606 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2607 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2608 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2609 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2610 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2611 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2612 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2613 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2614 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2615 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2616 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2617 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2618 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2619 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2620 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2621 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2622 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2623 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2624 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2626 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2627 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2629 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2630 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2631 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2632 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2633 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2634 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2635 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2636 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2637 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2638 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2639 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2640 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2641 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2642 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2643 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2645 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2646 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2647 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2648 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2649 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2651 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2652 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2653 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2654 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2655 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2656 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2657 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2658 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2659 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2660 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2661 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2662 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2663 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2664 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2665 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2666 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2667 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2668 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2669 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2670 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2671 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2672 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2673 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2674 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2675 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2676 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2677 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2678 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2679 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2680 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2681 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2682 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2683 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2684 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2685 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2686 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2687 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2688 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2689 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2690 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2691 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2692 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2693 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2695 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2696 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2697 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2698 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2699 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2700 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2701 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2703 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2704 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2705 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2706 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2707 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2708 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2709 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2710 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2711 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2713 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2714 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2715 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2716 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2717 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2718 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2719 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2720 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2721 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2722 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2723 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2724 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2725 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2726 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2729 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2730 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2731 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2732 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2733 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2734 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2735 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2736 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2737 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2738 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2739 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2740 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2741 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2742 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2743 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2744 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2745 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2746 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2747 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2748 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2749 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2750 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2751 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2752 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2753 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2754 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2755 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2757 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2758 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2759 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2761 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2762 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2763 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2764 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2766 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2767 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2768 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2769 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2770 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2771 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2772 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2773 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2774 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2775 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2776 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2778 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2779 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2780 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2781 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2782 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2783 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2784 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2785 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2786 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2787 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2788 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2789 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2790 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2791 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2792 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2793 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2794 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2795 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2796 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2797 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2798 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2799 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2800 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2801 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2802 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2804 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2805 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2806 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2807 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2809 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2810 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2811 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2812 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2813 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2814 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2815 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2816 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2817 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2818 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2819 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2820 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2822 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2823 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2824 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2825 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2826 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2827 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2828 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2829 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2830 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2831 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2832 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2833 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2834 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2835 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2836 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2837 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2838 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2839 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2840 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2841 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2842 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2843 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2844 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2845 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2846 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2847 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2848 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2849 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2850 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2851 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2852 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2853 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2854 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2855 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2856 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2857 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2858 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2859 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2860 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2862 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2864 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2865 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2866 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2867 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2868 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2869 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2870 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2871 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2872 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2873 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2874 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2875 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2876 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2877 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2878 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2880 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2881 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2882 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2883 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2884 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2885 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2886 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2887 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2888 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2889 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2890 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2891 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2892 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2893 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2894 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2895 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2896 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2897 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2898 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2899 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2902 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2903 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2904 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2905 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2906 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2907 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2909 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2910 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2911 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2912 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2913 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2914 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2915 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2916 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2917 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2919 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2920 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2921 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2922 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2923 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2924 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2925 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2926 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2927 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2928 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2929 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2930 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2931 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2932 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2933 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2934 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2935 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2936 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2937 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2939 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2940 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2941 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2942 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2943 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2944 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2945 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2946 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2947 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2948 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2949 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2950 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2951 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2952 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2953 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2954 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2956 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2957 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2958 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2959 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2960 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2961 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2962 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2963 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2964 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2965 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2966 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2967 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2968 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2969 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2970 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2971 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2972 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2973 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2974 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2976 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2977 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2978 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2979 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2980 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2981 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2982 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2983 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2984 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2985 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2986 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2987 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2988 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2989 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2990 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2991 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2992 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2993 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2994 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2995 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2996 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2997 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2998 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
2999 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3000 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3001 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3002 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3003 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3004 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3006 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3007 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3009 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3010 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3011 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3012 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3013 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3014 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3015 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3016 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3017 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3018 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3019 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3020 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3021 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3022 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3023 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3024 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3026 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3027 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3028 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3030 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3031 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3032 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3033 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3034 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3035 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3036 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3037 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3038 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3039 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3040 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3041 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3042 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3043 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3044 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3045 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3046 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3047 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3048 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3049 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3051 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3052 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3053 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3054 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3055 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3056 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3057 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3058 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3059 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3060 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3061 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3062 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3063 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3064 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3065 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3066 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3067 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3068 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3069 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3070 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3072 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3073 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3075 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3076 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3077 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3078 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3079 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3080 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3081 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3082 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3083 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3084 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3086 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3087 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3088 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3089 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3090 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3092 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3094 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3095 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3096 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3097 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3098 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3099 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3100 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3100 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3101 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3102 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3103 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3104 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3105 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3106 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3107 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3108 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3109 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3110 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3111 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3113 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3114 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3116 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3117 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3118 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3120 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3121 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3122 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3123 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3124 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3125 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3126 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3127 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3128 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3129 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3130 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3132 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3133 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3134 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3135 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3137 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3138 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3139 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3140 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3141 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3142 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3143 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3144 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3145 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3146 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3147 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3148 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3149 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3150 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3151 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3152 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3153 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3154 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3155 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3156 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3157 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3159 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3160 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3162 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3163 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3164 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3164 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3166 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3167 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3168 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3169 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3170 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3171 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3172 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3173 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3174 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3175 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3176 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3177 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3179 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3180 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3182 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3184 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3185 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3186 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3187 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3188 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3190 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3191 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3192 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3193 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3194 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3195 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3196 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3198 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3199 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3200 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3201 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3203 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3204 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3205 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3206 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3207 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3208 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3209 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3210 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3211 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3212 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3213 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3214 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3215 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3216 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3217 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3219 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3220 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3222 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3223 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3224 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3225 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3226 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3227 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3228 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3229 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3230 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3231 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3232 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3233 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3234 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3235 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3236 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3237 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3238 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3239 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3240 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3241 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3243 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3244 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3245 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3247 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3248 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3249 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3250 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3251 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3252 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3253 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3254 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3255 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3257 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3258 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3259 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3260 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3261 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3262 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3263 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3264 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3265 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3266 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3267 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3268 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3269 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3271 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3272 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3273 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3274 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3275 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3276 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3277 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3278 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3279 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3280 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3281 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3282 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3283 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3284 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3285 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3286 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3287 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3288 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3289 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3290 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3291 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3292 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3293 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3295 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3296 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3297 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3298 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3299 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3300 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3301 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3303 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3304 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3305 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3306 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3308 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3309 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3310 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3311 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3312 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3313 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3314 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3315 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3316 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3317 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3318 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3319 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3320 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3321 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3322 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3323 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3324 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3325 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3326 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3327 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3328 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3329 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3330 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3331 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3332 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3333 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3334 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3335 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3336 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3337 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3338 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3339 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3340 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3341 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3342 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3343 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3344 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3345 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3346 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3347 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3349 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3350 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3351 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3352 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3353 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3354 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3355 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3356 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3357 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3358 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3359 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3360 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3361 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3362 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3363 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3365 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3366 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3367 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3368 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3369 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3370 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3371 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3372 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3372 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3373 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3374 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3375 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3376 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3377 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3377 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3378 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3379 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3380 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3381 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3382 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3383 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3384 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3385 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3386 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3387 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3388 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3389 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3390 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3391 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3392 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3393 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3393 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3394 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3395 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3397 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3397 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3398 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3399 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3400 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3401 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3402 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3403 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3404 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3405 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3406 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3408 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3410 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3411 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3412 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3413 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3414 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3415 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3416 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3417 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3418 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3419 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3420 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3421 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3422 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3423 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3424 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3425 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3426 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3427 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3428 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3429 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3430 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3431 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3432 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3433 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3434 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3435 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3436 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3437 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3439 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3440 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3441 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3442 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3443 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3444 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3445 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3446 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3447 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3448 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3449 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3450 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3451 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3452 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3453 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3454 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3455 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3456 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3457 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3458 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3460 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3461 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3462 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3463 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3464 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3465 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3466 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3467 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3468 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3469 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3470 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3471 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3472 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3474 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3475 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3476 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3477 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3478 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3479 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3480 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3481 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3482 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3484 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3485 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3487 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3488 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3489 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3490 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3492 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3493 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3494 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3495 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3496 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3497 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3498 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3499 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3500 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3501 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3502 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3503 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3505 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3506 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3507 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3508 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3509 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3511 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3512 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3513 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3514 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3516 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3517 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3518 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3519 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3520 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3521 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3522 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3523 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3524 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3525 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3527 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3528 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3529 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3530 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
3531 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3532 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3533 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3534 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3535 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3536 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3537 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3538 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3539 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3540 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3541 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3542 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3543 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3544 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3545 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3546 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3547 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3548 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3549 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3550 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3551 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3552 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3553 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3554 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3555 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3556 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3557 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3558 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3559 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3560 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3561 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3562 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3563 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3564 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3565 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3566 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3567 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3568 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3569 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3570 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3571 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3572 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3573 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3574 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3576 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3577 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3578 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3579 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3580 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3581 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3582 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3583 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3584 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3585 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3586 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3587 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3588 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3589 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3590 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3591 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3592 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3593 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3594 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3595 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3596 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3597 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3598 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3599 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3600 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3601 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3602 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3603 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3604 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3605 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3606 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3607 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3608 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3609 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3610 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3611 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3612 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3613 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3615 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3616 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3617 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3618 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3619 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3620 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3621 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3623 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3624 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3625 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3626 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3627 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3628 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3629 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3630 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3631 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3632 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3633 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3634 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3635 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3636 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3637 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3638 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3639 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3640 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3641 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3642 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3643 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3644 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3645 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3646 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3647 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3648 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3649 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3650 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3651 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3652 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3653 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3654 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3655 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3656 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3657 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3658 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3659 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3660 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3661 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3663 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3664 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3665 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3666 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3667 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3668 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3669 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3670 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3671 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3672 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3673 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3675 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3676 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3677 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3678 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3679 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3681 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3682 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3684 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3685 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3686 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3687 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3688 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3689 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3690 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3691 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3692 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3693 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3694 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3695 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3696 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3697 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3698 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3700 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3701 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3702 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3703 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3705 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3706 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3707 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3708 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3709 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3710 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3711 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3712 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3713 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3714 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3715 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3716 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3717 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3718 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3719 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3720 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3721 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3722 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3723 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3724 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3725 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3726 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3727 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3729 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3730 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3731 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3732 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3733 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3734 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3735 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3736 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3737 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3738 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3740 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3741 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3743 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3745 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3746 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3747 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3748 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3749 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3750 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3751 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3752 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3753 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3754 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3755 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3756 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3757 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3758 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3759 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3760 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3761 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3762 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3763 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3766 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3767 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3769 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3770 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3771 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3772 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3773 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3774 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3775 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3776 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3777 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3778 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3779 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3780 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3782 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3783 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3784 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3785 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3786 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3787 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3788 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3789 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3790 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3791 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3792 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3793 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3794 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3795 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3796 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3797 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3798 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3799 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3800 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3802 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3803 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3804 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3805 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3806 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3807 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3808 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3809 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3810 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3812 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3813 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3814 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3815 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3816 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3817 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3818 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3819 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3820 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3821 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3822 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3824 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3826 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3828 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3829 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3830 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3831 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3832 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3833 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3834 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3835 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3836 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3837 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3838 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3839 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3840 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3841 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3842 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3843 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3844 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3845 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3846 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3847 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3848 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3849 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3850 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3851 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3852 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3853 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3854 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3856 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3857 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3858 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3859 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3860 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3861 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3862 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3863 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3864 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3865 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3866 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3867 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3868 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3869 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3870 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3871 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3872 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3873 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3874 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3875 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3876 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3877 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3878 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3879 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3880 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3881 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3882 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3883 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3884 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3886 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3887 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3888 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3889 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3890 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3891 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3892 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3893 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3894 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3896 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3897 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3898 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3899 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3900 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3902 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3903 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3904 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3905 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3906 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3907 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3908 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3909 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3910 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3911 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3912 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3914 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3915 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3916 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3917 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3918 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3919 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3920 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3921 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3922 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3923 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3924 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3925 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3926 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3927 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3928 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3929 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3930 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3931 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3932 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3933 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3934 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3935 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3936 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3938 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3939 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3940 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3941 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3942 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3943 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3945 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3946 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3947 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3948 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3949 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3950 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3952 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3953 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3955 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3956 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3958 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3959 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3960 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3961 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3962 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3963 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3964 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3965 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3966 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3967 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3968 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3969 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3970 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3971 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3972 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3973 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3975 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3976 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3977 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3978 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3979 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3980 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3981 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3982 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3983 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3985 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3986 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3987 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3988 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3989 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3990 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3991 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3992 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3993 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3994 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3995 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3996 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3997 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3998 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
3999 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4000 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4001 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4002 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4003 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4005 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4006 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4007 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4008 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4009 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4010 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4011 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4012 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4013 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4014 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4016 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4018 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4019 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4020 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4021 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4022 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4023 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4024 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4025 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4026 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4027 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4028 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4029 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4030 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4031 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4032 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4033 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4034 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4035 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4036 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4038 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4039 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4040 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4041 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4042 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4043 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4044 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4046 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4048 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4049 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4050 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4051 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4052 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4053 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4054 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4055 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4056 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4057 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4058 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4059 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4060 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4061 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4062 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4064 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4065 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4066 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4067 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4068 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4069 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4070 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4071 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4072 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4073 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4074 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4075 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4076 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4077 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4078 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4079 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4081 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4082 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4083 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4084 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4086 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4087 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4088 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4089 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4090 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4091 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4092 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4093 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4094 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4095 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4096 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4097 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4098 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4099 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4100 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4101 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4102 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4103 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4104 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4105 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4106 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4107 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4108 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4109 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4110 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4111 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4112 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4113 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4114 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4115 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4116 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4117 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4118 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4119 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4120 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4121 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4122 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4123 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4124 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4125 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4127 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4128 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4129 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4130 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4132 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4133 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4134 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4135 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4136 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4137 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4138 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4139 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4140 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4141 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4143 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4145 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4146 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4147 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4148 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4149 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4150 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4151 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4152 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4153 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4155 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4156 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4158 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4159 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4160 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4161 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4163 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4165 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4166 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4167 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4168 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4169 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4170 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4171 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4172 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4173 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4174 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4175 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4176 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4177 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4178 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4179 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4180 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4182 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4185 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4186 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4188 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4190 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4191 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4192 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4193 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4194 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4195 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4196 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4198 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4199 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4200 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4201 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4202 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4203 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4205 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4206 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4207 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4208 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4209 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4210 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4211 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4212 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4213 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4214 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4215 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4216 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4217 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4218 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4219 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4220 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4221 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4223 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4224 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4225 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4227 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4228 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4229 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4230 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4231 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4232 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4233 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4234 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4235 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4236 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4237 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4238 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4239 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4240 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4241 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4242 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4243 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4244 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4245 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4246 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4248 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4250 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4252 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4253 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4255 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4257 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4258 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4259 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4260 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4262 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4263 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4264 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4265 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4266 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4267 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4269 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4270 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4272 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4274 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4275 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4276 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4277 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4278 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4279 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4280 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4281 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4282 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4283 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4284 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4285 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4286 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4287 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4288 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4289 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4290 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4291 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4292 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4294 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4295 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4296 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4297 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4298 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4299 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4300 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4301 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4302 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4303 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4304 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4305 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4306 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4307 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4308 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4309 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4310 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4312 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4313 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4314 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4315 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4316 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4317 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4318 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4319 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4320 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4321 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4322 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4323 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4324 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4325 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4326 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4327 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4328 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4329 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4330 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4331 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4332 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4334 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4335 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4336 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4337 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4338 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4339 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4340 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4341 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4342 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4343 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4344 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4345 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4346 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4347 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4348 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4349 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4350 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4351 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4352 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4353 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4354 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4355 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4356 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4357 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4358 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4359 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4360 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4361 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4362 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4363 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4364 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4365 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4366 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4367 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4368 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4369 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4370 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4371 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4372 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4373 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4374 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4375 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4376 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4377 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4378 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4380 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4382 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4383 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4384 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4385 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4386 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4387 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4388 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4389 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4390 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4391 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4392 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4394 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4395 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4396 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4397 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4398 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4399 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4401 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4403 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4404 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4405 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4406 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4407 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4408 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4409 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4410 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4411 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4412 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4413 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4414 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4415 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4416 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4417 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4418 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4419 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4420 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4421 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4422 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4423 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4424 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4425 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4427 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4428 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4429 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4430 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4431 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4432 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4433 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4434 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4435 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4436 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4437 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4438 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4439 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4440 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4441 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4443 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4444 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4445 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4446 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4447 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4448 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4449 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4450 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4451 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4453 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4454 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4455 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4456 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4457 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4458 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4460 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4461 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4462 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4463 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4464 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4465 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4466 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4467 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4468 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4469 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4470 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4471 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4472 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4473 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4474 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4475 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4476 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4477 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4478 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4479 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4480 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4481 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4482 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4483 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4485 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4486 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4487 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4488 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4489 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4490 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4492 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4493 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4494 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4495 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4496 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4497 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4498 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4499 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4500 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4501 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4502 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4503 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4505 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4506 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4507 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4508 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4509 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4512 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4513 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4514 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4515 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4516 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4517 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4518 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4519 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4520 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4522 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4523 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4524 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4525 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4526 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4527 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4528 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4529 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4530 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4531 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4532 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4533 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4534 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4535 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4536 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4537 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4538 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4539 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4540 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4541 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4542 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4543 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4544 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4545 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4546 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4547 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4548 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4549 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4550 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4551 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4552 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4553 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4554 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4555 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4556 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4557 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4558 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4559 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4560 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4561 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4562 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4563 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4564 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4565 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4566 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4567 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4569 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4570 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4571 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4572 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4573 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4574 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4575 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4576 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4577 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4578 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4579 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4580 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4582 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4583 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4584 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4585 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4586 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4587 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4588 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4589 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4590 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4591 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4592 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4593 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4595 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4596 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4597 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4598 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4599 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4600 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4601 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4602 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4603 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4604 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4605 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4606 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4607 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4608 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4609 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4611 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4612 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4613 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4615 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4616 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4618 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4619 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4620 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4621 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4622 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4623 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4624 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4625 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4626 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4627 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4628 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4629 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4630 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4632 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4634 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4635 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4637 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4638 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4639 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4640 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4641 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4642 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4643 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4644 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4645 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4646 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4648 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4649 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4650 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4651 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4653 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4654 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4655 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4656 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4657 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4658 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4659 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4660 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4661 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4662 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4663 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4664 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4665 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4666 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4667 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4669 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4671 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4672 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4673 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4674 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4675 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4676 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4677 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4678 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4679 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4680 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4681 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4682 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4683 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4684 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4685 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4686 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4687 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4688 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4689 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4690 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4691 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4692 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4693 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4694 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4696 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4697 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4698 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4700 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4701 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4702 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4703 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4704 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4705 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4706 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4707 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4708 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4709 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4710 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4711 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4712 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4713 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4714 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4716 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4717 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4718 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4719 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4720 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4721 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4722 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4723 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4724 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4725 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4726 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4727 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4729 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4730 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4731 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4732 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4733 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4734 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4735 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4736 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4737 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4738 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4739 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4741 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4742 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4743 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4744 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4745 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4746 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4747 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4748 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4749 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4750 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4751 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4752 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4753 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4754 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4755 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4756 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4757 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4758 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4759 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4760 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4761 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4762 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4764 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4767 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4768 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4769 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4770 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4771 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4772 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4773 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4774 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4775 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4776 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4777 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4778 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4780 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4781 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4782 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4783 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4785 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4786 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4787 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4788 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4790 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4791 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4793 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4794 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4795 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4796 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4797 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4798 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4799 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4800 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4801 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4802 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4803 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4804 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4805 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4806 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4807 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4809 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4810 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4811 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4812 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4813 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4814 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4815 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4816 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4817 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4818 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4819 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4820 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4821 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4822 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4823 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4824 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4825 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4827 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4828 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4829 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4830 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4832 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4833 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4834 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4835 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4836 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4837 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4838 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4839 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4840 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4841 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4842 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4843 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4844 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4845 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4846 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4847 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4848 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4849 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4850 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4851 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4852 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4853 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4854 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4855 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4856 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4857 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4858 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4859 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4860 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4861 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4862 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4863 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4864 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4865 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4866 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4867 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4869 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4870 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4872 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4873 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4874 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4875 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4876 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4877 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4878 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4879 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4880 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4881 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4882 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4883 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4884 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4886 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4888 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4889 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4890 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4891 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4892 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4893 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4894 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4895 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4896 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4897 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4898 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4899 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4902 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4903 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4904 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4905 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4906 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4907 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4908 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4909 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4910 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4911 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4912 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4913 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4914 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4915 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4916 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4917 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4918 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4919 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4920 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4921 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4922 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4923 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4924 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4925 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4926 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4927 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4928 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4929 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4930 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4931 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4932 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4933 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4934 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4935 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4936 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4937 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4938 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4939 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4940 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4941 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4942 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4943 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4944 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4945 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4946 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4947 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4948 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4949 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4950 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4951 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4952 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4954 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4955 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4956 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4957 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4958 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4959 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4960 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4961 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4962 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4963 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4964 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4965 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4966 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4967 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4968 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4969 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4970 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4971 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4972 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4973 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4974 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4975 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4976 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4977 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4979 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4980 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4981 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4982 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4983 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4984 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4985 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4986 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4987 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4988 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4989 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4990 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4991 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4992 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4993 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4994 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4995 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4997 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
4998 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5000 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5001 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5002 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5003 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5004 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5005 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5006 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5007 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5008 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5009 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5010 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5011 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5012 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5013 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5014 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5016 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5017 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5018 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5019 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5020 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5021 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5022 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5023 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5024 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5025 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5026 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5027 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5028 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5029 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5030 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5031 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5032 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5033 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5034 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5035 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5036 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5038 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5040 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5041 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5042 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5043 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5044 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5045 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5047 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5048 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5049 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5050 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5051 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5052 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5053 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5054 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5055 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5056 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5057 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5058 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5059 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5060 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5061 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5062 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5063 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5065 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5066 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5067 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5068 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5069 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5070 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5071 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5072 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5073 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5074 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5075 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5077 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5078 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5080 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5081 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5082 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5083 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5084 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5086 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5087 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5088 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5089 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5090 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5091 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5092 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5093 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5094 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5095 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5096 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5097 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5098 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5099 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5100 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5101 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5102 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5103 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5104 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5105 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5106 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5107 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5108 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5110 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5111 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5112 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5113 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5114 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5115 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5116 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5117 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5118 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5119 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5120 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5121 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5122 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5123 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5124 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5125 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5126 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5127 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5128 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5129 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5130 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5132 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5133 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5134 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5135 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5136 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5137 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5138 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5139 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5140 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5141 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5142 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5144 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5146 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5147 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5148 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5149 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5150 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5151 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5152 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5153 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5154 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5155 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5156 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5157 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5158 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5159 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5161 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5162 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5163 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5164 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5165 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5166 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5167 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5168 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5169 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5170 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5171 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5172 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5173 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5174 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5175 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5176 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5177 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5178 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5179 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5180 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5182 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5184 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5185 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5186 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5187 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5188 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5190 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5191 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5192 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5193 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5195 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5196 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5198 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5199 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5200 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5201 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5202 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5203 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5204 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5206 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5207 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5208 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5210 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5211 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5212 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5213 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5214 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5215 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5216 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5217 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5218 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5219 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5220 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5221 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5222 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5223 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5224 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5226 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5227 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5228 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5229 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5230 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5231 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5232 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5233 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5234 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5235 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5236 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5237 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5238 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5239 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5240 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5241 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5242 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5243 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5244 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5245 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5246 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5247 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5248 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5249 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5250 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5251 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5252 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5253 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5254 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5257 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5258 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5259 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5260 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5261 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5262 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5263 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5264 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5265 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5266 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5267 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5268 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5269 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5270 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5272 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5273 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5274 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5275 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5276 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5277 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5278 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5279 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5280 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5281 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5282 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5284 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5285 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5286 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5287 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5288 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5290 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5291 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5293 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5294 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5295 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5296 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5297 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5298 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5299 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5300 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5301 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5302 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5303 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5304 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5305 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5306 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5307 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5308 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5310 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5311 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5312 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5313 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5314 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5315 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5316 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5318 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5319 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5320 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5321 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5322 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5323 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5324 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5325 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5326 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5328 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5329 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5331 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5332 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5333 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5334 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5336 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5337 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5338 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5339 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5340 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5341 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5342 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5343 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5344 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5345 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5346 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5347 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5348 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5349 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5350 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5351 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5352 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5353 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5354 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5355 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5356 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5357 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5358 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5359 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5360 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5361 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5362 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5363 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5364 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5365 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5366 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5367 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5369 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5370 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5371 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5372 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5374 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5375 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5376 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5377 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5378 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5379 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5380 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5381 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5382 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5383 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5384 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5385 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5386 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5387 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5388 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5389 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5390 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5391 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5392 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5393 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5394 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5395 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5396 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5397 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5398 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5399 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5400 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5401 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5402 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5403 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5404 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5405 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5406 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5407 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5408 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5409 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5410 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5411 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5412 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5413 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5415 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5416 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5417 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5418 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5419 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5420 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5421 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5423 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5424 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5425 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5426 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5427 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5428 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5429 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5430 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5431 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5432 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5433 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5434 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5435 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5436 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5437 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5438 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5439 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5440 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5441 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5442 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5443 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5444 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5445 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5446 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5447 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5448 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5449 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5450 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5451 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5452 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5453 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5454 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5455 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5456 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5457 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5458 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5459 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5460 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5461 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5462 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5463 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5464 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5465 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5466 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5467 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5468 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5469 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5470 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5471 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5472 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5473 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5474 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5475 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5476 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5478 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5479 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5480 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5481 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5482 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5483 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5484 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5485 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5486 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5487 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5488 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5489 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5490 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5491 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5492 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5493 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5494 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5495 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5496 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5497 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5498 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5499 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5500 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5501 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5502 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5503 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5505 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5506 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5507 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5508 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5509 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5511 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5512 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5513 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5514 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5515 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5516 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5517 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5518 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5519 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5520 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5521 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5522 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5523 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5524 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5526 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5527 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5528 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5529 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5530 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5531 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5532 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5533 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5534 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5535 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5536 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5537 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5538 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5539 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5540 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5541 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5542 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5543 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5544 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5545 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5546 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5548 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5549 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5550 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5551 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5552 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5553 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5554 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5555 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5556 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5557 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5558 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5559 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5560 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5561 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5563 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5564 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5565 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5566 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5568 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5569 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5570 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5571 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5572 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5573 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5574 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5575 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5576 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5577 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5578 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5579 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5580 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5581 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5582 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5583 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5584 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5585 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5586 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5587 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5589 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5590 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5591 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5592 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5593 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5594 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5595 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5596 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5597 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5598 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5599 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5600 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5601 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5602 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5603 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5604 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5605 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5606 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5607 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5608 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5609 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5610 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5611 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5612 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5613 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5614 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5615 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5616 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5617 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5618 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5620 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5621 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5622 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5623 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5625 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5626 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5627 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5628 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5629 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5630 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5631 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5632 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5633 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5634 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5635 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5636 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5638 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5639 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5640 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5641 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5642 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5643 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5644 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5645 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5646 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5647 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5648 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5649 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5650 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5651 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5652 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5653 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5654 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5655 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5656 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5657 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5658 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5659 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5660 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5661 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5662 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5663 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5664 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5665 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5666 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5667 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5668 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5669 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5670 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5671 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5672 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5674 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5675 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5677 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5678 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5679 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5680 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5681 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5682 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5683 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5684 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5685 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5686 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5687 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5688 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5689 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5690 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5691 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5692 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5693 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5695 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5696 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5698 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5699 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5700 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5701 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5702 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5703 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5704 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5705 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5706 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5707 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5708 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5709 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5710 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5711 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5712 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5714 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5715 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5717 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5718 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5720 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5721 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5722 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5723 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5725 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5726 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5727 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5729 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5730 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5731 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5732 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5733 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5734 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5735 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5736 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5737 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5738 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5739 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5740 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5741 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5742 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5743 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5744 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5745 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5746 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5747 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5748 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5749 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5750 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5751 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5752 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5753 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5754 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5755 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5756 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5757 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5758 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5759 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5760 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5761 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5762 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5763 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5764 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5766 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5767 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5768 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5769 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5770 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5771 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5773 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5774 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5775 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5776 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5778 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5780 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5781 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5782 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5783 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5784 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5785 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5786 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5787 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5788 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5789 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5790 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5791 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5792 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5793 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5794 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5795 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5796 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5797 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5798 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5799 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5800 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5801 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5802 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5803 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5804 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5805 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5806 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5807 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5808 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5809 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5810 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5811 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5812 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5813 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5814 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5815 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5816 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5817 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5818 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5819 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5820 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5821 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5822 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5823 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5825 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5826 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5827 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5828 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5829 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5830 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5831 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5832 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5833 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5834 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5835 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5836 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5837 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5838 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5839 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5840 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5841 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5842 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5843 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5844 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5845 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5846 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5847 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5848 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5849 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5850 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5852 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5853 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5854 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5855 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5856 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5857 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5858 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5859 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5860 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5861 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5862 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5863 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5864 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5865 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5867 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5868 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5869 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5870 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5871 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5872 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5873 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5874 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5875 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5876 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5877 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5878 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5879 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5880 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5881 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5882 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5883 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5884 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5885 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5886 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5887 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5888 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5889 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5890 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5891 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5892 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5893 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5894 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5895 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5896 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5897 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5898 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5899 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5900 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5902 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5904 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5905 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5906 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5907 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5908 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5909 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5910 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5911 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5912 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5913 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5914 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5915 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5916 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5917 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5918 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5920 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5921 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5922 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5923 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5924 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5925 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5926 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5927 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5928 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5929 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5930 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5931 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5932 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5933 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5934 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5936 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5937 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5938 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5940 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5942 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5943 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5944 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5945 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5946 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5947 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5948 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5949 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5950 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5951 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5952 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5953 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5954 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5956 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5957 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5958 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5959 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5960 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5961 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5962 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5963 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5964 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5965 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5966 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5967 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5968 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5969 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5970 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5971 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5972 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5973 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5974 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5975 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5976 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5978 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5979 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5980 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5981 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5982 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5983 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5984 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5985 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5986 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5987 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5988 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5989 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5990 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5991 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5992 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5994 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5995 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5996 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5997 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5998 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
5999 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6000 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6001 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6002 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6003 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6004 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6005 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6006 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6007 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6008 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6009 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6010 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6011 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6012 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6013 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6014 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6015 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6016 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6017 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6018 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6020 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6021 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6022 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6023 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6024 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6025 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6026 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6027 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6028 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6029 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6030 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6031 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6032 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6033 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6034 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6036 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6037 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6038 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6039 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6040 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6041 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6042 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6043 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6044 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6045 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6046 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6047 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6048 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6049 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6050 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6051 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6052 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6053 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6054 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6055 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6056 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6057 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6058 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6059 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6060 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6061 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6062 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6063 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6064 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6065 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6066 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6067 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6068 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6069 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6070 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6071 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6073 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6074 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6075 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6076 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6077 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6078 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6079 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6080 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6081 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6082 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6083 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6084 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6086 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6087 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6088 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6089 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6090 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6091 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6092 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6093 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6094 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6095 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6096 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6097 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6098 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6099 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6100 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6101 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6102 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6103 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6105 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6106 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6107 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6108 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6109 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6110 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6111 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6112 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6113 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6114 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6115 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6116 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6117 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6118 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6119 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6120 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6121 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6122 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6123 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6124 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6125 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6126 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6127 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6128 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6130 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS
6131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6132 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6133 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6134 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6135 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6136 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6137 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6138 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6139 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6141 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6142 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6143 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6144 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6145 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6146 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6147 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6148 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6149 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6150 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6151 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6152 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6153 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6154 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6155 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6156 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6157 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6158 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6159 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6160 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6161 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6162 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6163 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6164 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6165 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6166 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6167 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6168 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6170 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6172 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6173 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6174 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6175 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6176 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6177 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6178 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6179 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6180 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6182 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6184 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6185 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6186 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6187 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6190 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6192 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6193 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6194 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6195 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6196 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6198 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6199 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6200 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6201 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6202 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6204 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6205 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6206 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6207 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6208 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6209 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6211 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6212 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6213 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6214 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6215 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6216 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6217 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6218 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6219 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6220 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6221 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6222 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6223 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6224 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6225 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6226 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6227 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6228 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6229 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6230 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6231 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6232 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6233 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6234 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6235 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6236 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6237 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6238 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6239 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6241 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6242 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6243 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6244 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6245 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6246 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6247 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6248 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6249 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6250 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6252 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6253 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6254 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6255 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6257 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6258 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6259 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6261 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6262 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6263 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6264 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6265 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6266 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6267 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6268 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6269 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6270 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6271 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6272 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6273 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6274 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6275 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6276 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6277 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6279 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6280 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6281 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6282 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6283 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6284 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6285 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6286 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6287 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6289 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6290 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6291 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6292 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6294 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6295 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6296 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6297 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6298 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6299 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6300 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6301 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6302 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6303 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6304 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6305 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6306 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6307 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6308 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6309 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6310 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6311 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6312 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6313 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6314 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6315 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6316 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6317 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6318 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6319 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6320 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6321 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6322 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6323 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6324 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6325 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6326 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6327 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6328 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6329 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6330 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6331 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6332 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6333 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6334 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6335 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6336 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6337 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6338 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6339 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6340 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6341 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6342 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6343 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6344 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6345 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6346 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6347 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6348 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6349 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6350 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6351 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6352 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6353 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6354 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6355 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6357 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6358 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6359 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6360 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6361 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6362 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6363 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6364 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6365 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6366 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6367 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6368 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6369 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6370 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6371 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6373 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6374 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6375 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6376 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6377 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6378 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6379 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6380 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6381 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6382 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6383 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6384 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6385 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6386 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6387 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6388 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6389 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6390 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6391 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6392 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6393 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6394 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6395 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6396 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6397 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6398 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6399 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6400 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6401 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6402 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6403 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6404 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6406 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6408 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6410 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6411 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6412 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6413 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6414 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6415 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6416 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6417 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6418 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6419 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6420 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6421 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6422 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6423 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6424 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6426 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6427 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6428 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6429 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6431 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6432 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6433 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6434 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6436 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6438 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6439 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6440 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6441 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6442 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6443 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6444 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6445 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6447 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6448 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6449 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6450 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6452 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6453 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6454 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6455 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6456 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6457 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6458 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6459 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6460 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6461 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6462 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6463 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6464 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6465 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6466 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6467 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6468 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6469 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6470 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6471 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6472 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6473 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6475 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6476 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6477 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6478 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6479 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6480 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6481 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6482 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6483 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6484 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6485 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6486 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6488 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6489 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6490 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6491 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6492 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6493 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6494 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6495 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6496 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6497 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6498 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6500 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6501 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6502 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6503 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6505 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6506 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6507 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6509 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6511 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6512 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6513 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6514 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6515 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6516 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6517 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6518 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6519 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6520 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6521 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6522 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6523 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6524 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6525 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6526 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6527 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6528 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6529 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6530 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6531 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6532 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6533 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6534 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6535 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6536 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6537 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6538 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6539 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6540 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6541 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6542 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6543 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6544 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6545 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6546 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6547 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6548 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6549 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6550 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6551 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6552 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6553 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6555 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6556 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6557 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6558 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6559 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6560 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6561 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6562 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6563 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6564 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6565 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6566 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6567 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6568 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6569 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6570 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6571 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6572 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6573 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6574 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6575 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6576 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6578 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6579 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6580 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6581 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6582 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6583 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6584 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6585 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6586 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6587 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6588 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6589 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6590 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6591 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6592 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6594 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6595 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6596 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6597 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6598 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6599 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6600 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6601 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6602 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6603 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6604 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6605 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6606 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6607 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6608 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6609 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6610 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6611 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6612 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6613 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6614 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6615 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6616 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6617 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6618 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6619 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6620 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6621 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6622 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6623 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6624 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6625 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6626 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6627 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6628 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6629 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6630 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6631 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6632 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6633 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6634 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6635 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6636 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6637 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6638 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6639 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6640 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6641 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6642 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6643 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6644 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6645 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6646 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6647 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6648 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6649 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6650 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6651 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6652 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6653 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6654 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6655 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6656 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6657 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6659 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6660 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6661 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6663 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6664 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6665 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6666 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6667 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6668 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6669 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6670 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6671 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6672 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6673 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6674 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6675 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6676 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6677 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6678 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6679 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6680 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6681 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6682 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6683 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6684 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6685 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6686 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6687 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6688 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6689 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6690 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6691 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6692 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6694 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6695 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6696 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6697 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6698 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6699 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6700 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6701 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6702 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6703 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6704 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6706 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6707 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6708 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6709 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6710 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6711 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6712 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6713 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6714 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6715 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6716 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6717 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6718 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6719 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6720 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6721 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6722 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6723 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6724 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6725 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6726 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6727 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6729 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6730 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6731 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6732 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6733 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6734 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6736 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6737 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6738 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6739 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6740 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6741 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6742 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6743 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6744 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6745 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6746 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6747 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6748 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6749 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6750 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6751 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6752 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6753 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6754 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6755 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6756 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6757 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6758 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6759 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6760 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6761 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6762 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6763 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6764 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6766 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6767 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6768 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6769 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6770 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6771 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6772 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6773 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6774 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6775 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6777 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6778 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6779 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6780 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6781 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6782 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6783 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6784 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6785 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6786 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6787 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6789 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6790 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6792 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6793 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6794 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6795 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6796 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6797 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6798 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6799 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6800 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6801 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6802 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6803 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6804 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6805 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6806 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6807 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6808 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6809 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6810 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6811 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6812 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6813 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6814 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6815 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6816 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6817 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6818 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6819 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6820 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6821 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6822 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6823 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6824 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6826 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6827 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6828 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6829 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6830 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6831 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6832 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6833 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6834 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6835 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6836 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6837 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6838 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6839 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6840 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6841 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6842 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6843 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6844 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6845 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6846 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6847 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6848 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6849 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6850 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6851 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6852 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6853 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6854 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6855 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6857 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6858 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6859 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6860 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6861 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6862 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6863 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6864 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6865 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6866 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6867 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6868 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6869 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6870 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6871 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6872 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6873 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6874 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6875 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6876 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6877 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6878 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6879 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6880 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6881 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6882 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6883 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6884 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6885 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6886 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6887 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6888 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6889 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6890 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6891 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6892 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6894 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6895 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6896 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6897 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6898 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6899 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6900 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6902 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6903 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6904 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6905 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6906 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6907 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6908 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6909 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6910 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6911 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6912 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6913 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6914 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6915 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6916 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6917 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6918 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6920 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6921 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6922 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6923 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6924 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6925 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6926 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6927 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6928 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6929 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6930 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6932 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6933 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6934 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6936 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6937 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6938 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6939 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6940 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6941 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6942 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6943 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6944 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6945 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6946 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6947 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6948 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6949 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6950 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6951 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6952 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6953 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6954 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6955 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6956 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6957 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6958 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6959 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6960 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6961 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6962 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6963 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6964 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6965 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6966 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6967 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6968 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6969 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6970 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6971 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6972 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6973 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6975 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6977 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6978 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6979 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6980 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6981 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6983 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6984 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6985 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6986 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6987 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6988 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6989 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6990 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6991 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6992 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6993 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6994 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6995 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6996 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6997 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
6999 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7001 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7002 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7004 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7005 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7006 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7007 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7008 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7009 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7010 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7011 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7012 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7013 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7014 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7015 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7016 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7017 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7018 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7019 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7020 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7021 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7022 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7023 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7024 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7025 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7026 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7027 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7028 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7029 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7030 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7031 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7032 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7033 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7034 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7035 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7036 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7037 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7038 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7039 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7040 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7041 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7042 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7043 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7044 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7045 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7046 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7047 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7048 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7049 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7050 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7051 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7052 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7053 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7054 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7055 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7056 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7057 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7058 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7059 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7060 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7061 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7062 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7063 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7064 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7065 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7066 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7067 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7068 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7069 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7070 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7071 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7072 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7073 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7074 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7075 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7077 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7078 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7079 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7080 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7081 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7082 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7083 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7086 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7088 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7089 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7090 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7091 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7092 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7093 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7094 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7095 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7096 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7097 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7098 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7100 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7101 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7103 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7104 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7105 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7106 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7107 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7108 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7109 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7110 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7111 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7112 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7114 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7115 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7116 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7117 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7118 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7119 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7120 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7121 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7122 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7123 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7124 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7125 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7126 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7127 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7128 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7129 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7130 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7132 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7133 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7134 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7135 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7136 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7138 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7139 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7140 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7141 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7142 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7143 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7144 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7145 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7146 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7147 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7148 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7149 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7151 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7152 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7153 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7154 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7155 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7156 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7157 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7158 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7159 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7160 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7161 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7162 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7163 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7164 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7165 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7166 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7167 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7168 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7169 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7170 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7171 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7172 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7173 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7174 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7175 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7176 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7177 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7178 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7179 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7180 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7182 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7184 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7185 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7186 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7187 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7188 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7190 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7192 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7193 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7194 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7195 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7196 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7198 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7199 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7200 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7201 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
7202 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uSwith Linux Mint 19.3 XFCE it's not suitable for Linuxcnc ( huge understatment )
Next- Debian Buster and see how it does with that.
Last edit: 01 Nov 2020 03:01 by my1987toyota.
- BeagleBrainz
- Visitor
01 Nov 2020 03:01 #187965
by BeagleBrainz
Replied by BeagleBrainz on topic Results of latency test, list of computers tested for use with LinuxCNC
Did you notice you aren't running a RT kernel ?
You just booted into a "generic" kernel ?
Hence the reason the latency is unusable.
- my1987toyota
- Thank you received: 448
01 Nov 2020 03:05 #187966
by my1987toyota
interesting I must have missed something.
I thought you either had RTAI or Preempt-RT
Replied by my1987toyota on topic Results of latency test, list of computers tested for use with LinuxCNC
- seuchato
- Thank you received: 126
01 Nov 2020 03:07 #187968
by seuchato
Replied by seuchato on topic Results of latency test, list of computers tested for use with LinuxCNC
I'll add a check on RT or RTAI kernels to prevent this.
The following user(s) said Thank You: my1987toyota
- BeagleBrainz
- Visitor
01 Nov 2020 03:10 #187969
by BeagleBrainz
Hahahahaha I just suggested that in the original script thread.
If you are using my install ISO and update the kernel the default kernel will be the one that has just been installed.
- seuchato
01 Nov 2020 03:20 #187971
by seuchato
Must have overlooked that.
- Hardware & Machines
- Computers and Hardware
- Results of latency test, list of computers tested for use with LinuxCNC
Time to create page: 0.394 seconds
