Remora 1.0.0_rc released for testing
5 years 1 week ago #224054 by Cncninja
That would be awesome! Thanks
5 years 1 week ago #224056 by Cncninja
Will the STM vs LPC have a faster step rate? I know some said 4 times faster SPI buss on the STM, but does that equate to a faster step Hz, or is the RPI the limiting factor? I already have the LPC-based SKR1.4pro, im just wondering for future builds. Thanks Much
5 years 1 week ago - 5 years 1 week ago #224060 by scotta
Hi, this is the next part of the development now that the STM32F4 is supported. I've got a cunning plan to double the step rate with the current servo thread frequency but also I'm working on having the Base Frequency as part of the config.txt so that we can play with max step rates. I think 80khz would be achievable now. That's 1000mm/s if I get the step doubling working. 100khz might even be possible.
Last edit: 5 years 1 week ago by scotta.
5 years 1 week ago #224291 by Aaroncnc
Cncninja post=224019 userid=28123Was the LPC also updated? I have the skr1.4 turbo, I have not been able to set up any peripherals on the board other than XYZ step gen, I would love a HAL file that was pre-configured for 4 axes and used the built-in home, probe, fan=flood, bed heater=spindle for mill use. If anyone could help that would be awesome i posted what I have so far in the other thread.
Please find the attached files i did not have time to flash my board to make sure they work but should be enough for you to see.
Also if you are having trouble with the config for the skr i have made a tool.
github.com/aaroncnc/Remora-GUI-Config-Tool
It needs a few changes for the newest branch of remora but the only change is the name for TMC and i will have a updae soon for the tool.
The following user(s) said Thank You: Cncninja
5 years 1 week ago - 5 years 1 week ago #224306 by Aaroncnc
I have updated my config tool with the new TMC changes.
I am still lacking the motor enable option and the TMC com pins are hard set for a skr 1.4 board.
I will try to add the other 2 items soon.
Please let me know of any feedback or confusion/improvements.
Also i wish i knew a better way to code as i have soo many repeats that i feel i should try to use a variable variable.
Last edit: 5 years 1 week ago by Aaroncnc.
The following user(s) said Thank You: Bari
5 years 6 days ago #224313 by cakeslob
What is the situation with the motorpower pin? I see a module but I dont see it in the sample config for skr2.
is it the same as posted in the thread? or is it not needed?
"Thread": "On load", "Type": "Motor Power", "Comment": "Enable motor power SKR2", "Pin": "PC_13"
