- Thank you received: 45
The Remora thermistor module already has some basic protection for a broken / disconnected sensor. When disconnected the thermistor calculations output a negative number, which cannot be possible in real life. In this condition the logic then outputs a stupidly high 999degC which is also not possible. Any PID controller seeing this quickly sends the SP command to zero.Thanks. Are you going to post it here or git?
Run away can happen for a few reasons. Most common is hardware failure such as thermistor wire develops a break or comes lose/ separates from the device being heated.
Without any watch dog it will keep trying to heat until it destroys itself.
This would be best done at the lowest level that if the heater is not responding it would give up vs going forever.
