- Thank you received: 280
Ok, so that confirmed it was the LinuxCNC side. The board would have only accepted every 64th SPI transmission, which would explain the following error.Just loaded the new one, I cannot get the stm32 to run at 16th divisor, it puts out "SPI data error" in serial when I try to connect and "Bad SPI payload = 32303a30" on linuxcnc
I recompiled with the stm32 to 32 divider and it can operate and I dont get spi error or following error.
Hi, if there are no command line arguments then the component defaults back to the LPC1768 setting for compatibility. The default BASE frequency is 40khz.What boards support what rates?
Is there a default rate if none is provided in the config?
