Remora 1.0.0_rc released for testing
5 years 6 days ago #224317 by Bari
We have to walk here before we can run but Mbed OS adds some overhead to generating steps. Someone can always fork this to a different real time OS or go OS free or even use assembly to max out performance.
5 years 6 days ago #224329 by scotta
Remora uses the Mbed bare-metal profile, so no overhead of an RTOS.
5 years 6 days ago #224331 by Bari
5 years 6 days ago #224336 by scotta
What is the situation with the motorpower pin? I see a module but I dont see it in the sample config for skr2.
is it the same as posted in the thread? or is it not needed?
"Thread": "On load", "Type": "Motor Power", "Comment": "Enable motor power SKR2", "Pin": "PC_13"
Hi, the only sample config.txt is the one I posted. So yes this Motor Power module is needed.
5 years 5 days ago #224460 by Cncninja
Thanks so much, ill give this a try.
5 years 5 days ago #224534 by Aaroncnc
config tool updated
added the skr2 to the boards options (it will auto add the motor power enable to your config file)
Added TMC rx pins to the gui
Did a code refactor from 1,400 lines down to sub 250 lines
github.com/aaroncnc/Remora-GUI-Config-Tool
Do you think it would be worth the effort to start adding in a HAL and ini generation to the program?
So the user could setup a basic machine kinda like tha paraport setup there is now.
Time to create page: 0.371 seconds
