Remora 1.0.0_rc released for testing
4 years 11 months ago #226700 by cakeslob
I chose the Mks Robin E3 as the dev board as most of the SKR boards share the SPI used for communications with the SD card. I think I have a work around for this but will need to get a board to test 100%.
I see that... I was about to load it on to a btt board with 103, but yeah, the sd is spi, and all the alts are being used by stepper signals....., which can serve as a segway into a question ,
What are your thoughts on writing the config to the i2c eeprom? Looks like a lot of boards have eeproms already, or alternately, wasnt mhel loading his via uart at startup or something like that?
4 years 11 months ago #226703 by wazza77
thanks, mate
these bords are so cheap the last one I believe is only AUD $17 I literally throw them in the cart if I'm ordering parts from suppliers that have them. with flash,rtc and all the io available.
4 years 11 months ago #226837 by scotta
Hi, which F103 SKR board do you have? I'd like to try out my idea but will be only able to test with a breadboard setup. I can work up the code and get you to test on the real board if that's ok?
4 years 11 months ago #226840 by cakeslob
github.com/bigtreetech/BIGTREETECH-SKR-CR6
Just let me know what I gotta do, im down for whatever
4 years 11 months ago #226947 by scotta
Hmm, this is a wired one. There's no schematic available for the board and the pinout doesn't make a whole lot of sense either. There does not appear to be an SPI interface exposed on the available headers.
4 years 11 months ago #226956 by cakeslob
yeah, spi1 is on the sd card, spi2 and 3 are used for step/direction on x and e. soldering to the sd card is minor details, just let me know
