- Thank you received: 489
Hi, yes absolutely correct. I was directly contacted by a user who wanted to use this board for a gantry router. He's currently getting it going and learning LinuxCNC along the way. This board gives full flexibility on IO, so heaps of potential.Hi Scotta
The ARCH_MAX.bin file I assume is the SEED ARCH MAX board so I should be able to run this on the STM32F407VET6 Black board? os.mbed.com/users/hudakz/code/STM32F407VET6_Hello/shortlog/
as I use seed arch max profile to program it in mbed. if so this will really make using linuxcnc very accessible as these boards are cheap and available I have 3 on my desk right now I normally use eclipse or now STM cube as my environment. I have a mill running with EtherCAT servo drives.
so this will be tested on my CNC plasma table so a very high rf noise environment so it should be interesting
Hi Aaron, thanks for clarifying things for the others. Your work on the config tool means you're totally across the capabilities of Remora.
Bari, As far as IO's go each stepper requires a Step and Dir.
The inputs and out puts are separate from the step gens.
so they are not taken up by step and dir
Remora supports 8 drivers.
16 inputs and 16 outputs.
The only weird thing that takes up an input is the encoder index pulse but i don't think it's a big deal as it's only important on a spindle or rotary axis.
The pwm does not take up an output and there are 8 pwm channels.
Hi, thanks for the clarification. I'll update things to call it BLACK_F407E as I have set it up to use the SDIO.Hi Scotta
The seed arch max uses SPI2 for the sd card whereas the black uses SDIO. I tried compiling in MBED studio last night but I had a few issues
but at 3 am I wasn't going to push it any further
