- Bari
- Thank you received: 234
17 Nov 2022 23:30 #256985
by Bari
Replied by Bari on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Scott,
Do you have a public repo yet for the new RT1052 fork?
- scotta
- Thank you received: 489
17 Nov 2022 23:48 #256988
by scotta
The following user(s) said Thank You: Bari, tommylight, MX_Master, mrbubble
- scotta
18 Nov 2022 04:54 #257005
by scotta
Stepper motors are moving
The following user(s) said Thank You: Bari, tommylight, pommen, MX_Master, Murphy, RogEnk
- scotta
20 Nov 2022 05:23 #257142
by scotta
We're very close to have a fully functional RT1052 controller boards! Some fun this weekend tracing out the remaining Inputs and Outputs back to their respective pads.
All IO on the NVEM and EC300 is working. Funny thing is that the new NVEM is now missing two inputs (X1IN and B1).
Repo is up to date. Spindle PWM and NVMPG communications are all that needs to be completed.
The following user(s) said Thank You: MX_Master, Murphy, RogEnk
- disneysw
20 Nov 2022 11:14 #257153
by disneysw
Replied by disneysw on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Sorry I would like to try your code out but I have got confused by the long forum thread and discussions about mixed boards and processors and I have two simple questions
1. I have one of the EC300 STM32F2 boards with a PWM chip. From your posts the HEX file for the STM32F2 NVEM board should work on it as is?
2. In the post dated 20 Nov you mention "All IO on the NVEM and EC300 is working." but the repository at github.com/scottalford75/Remora-NVEM no new commits for a couple of months - am I looking at the right repository?
Thanks for the good work!
- scotta
20 Nov 2022 20:35 #257178
by scotta
Hi, yes a very long thread moving from topic to topic. Not so easy to digest.
1. If your EC300 has the F2 chip then yes the NVEM bin file is what you need. Note that it has not been tested on the old EC300.
2. There is a new repo for the RT1052 based boards. github.com/scottalford75/Remora-RT1052
- disneysw
27 Nov 2022 13:45 #257732
by disneysw
I managed to spend some time with the EC300 and the Remora firmware and was able to get the basics working. This was once I figured out the HAL input numbers were the "data bit" numbers in the uploaded config file and not the EC300 text labels!
I also had to add:
loadrt lowpass count=1
loadrt abs count=1
addf scale.0 servo-thread
addf lowpass.0 servo-thread
addf abs.0 servo-thread
setp scale.0.gain 0.1
net spindle-cmd-rpm spindle.0.speed-out => scale.0.in
net spindle-cmd-rpm-abs scale.0.out => abs.0.in
net spindle-speed-DAC abs.0.out => remora.SP. 0
to the HAL file to get the spindle to output 0-10V for a 0-1000RPM range.
The only thing lacking is a spindle encoder module to handle more than just an index pulse.
I also had to add:
loadrt abs count=1
The following user(s) said Thank You: scotta, Murphy
- REX299
- Visitor
28 Nov 2022 12:26 #257844
by REX299
Replied by REX299 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hello
scotta
I
I bought EC500 from China market to use Mach3,They said my EC500 is version 5. As a saw there are some changed in board layout. (see the pictures). This such thing not working with Home and limit switch, another big issue makes me can live with it is Probe command "G31" not working! I dont got any support from that company!
Very interesting witch your working, Does has any firmware can run LinuxCNC on this board now? I go through page to page and get some Infor that till now only work with older version of ec500 using STM32 processor, And RT1052 is on develop?
Thank you for your great work
Best regard.
Best regard.
- scotta
28 Nov 2022 21:54 #257899
by scotta
Hi, yes your board should be supported by the work to port Remora to the RT1052. I'll have an EC500 for testing in a week or so. Welcome to LinuxCNC!Hello scottaI
Best regard.
The following user(s) said Thank You: heiterkiter
- mrbubble
02 Dec 2022 04:23 #258292
by mrbubble
There's a ton of potential with this rt1052, I'm thinking servos..
— Four FlexPWMs
– Up to 8 individual PWM channels for each
– 16-bit resolution PWM suitable for Motor Control applications
— Four Quadrature Encoder/Decoders
Your quick start instructions for getting the toolchain setup are stellar. Thank you so much!
Cannot wait for my CIMSS device to arrive.
Replied by mrbubble on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Found this when down the rabbit hole of getting Remora SKR running on a cheap fan less Linux PC SoCJust created the dev branch.
https:/github.com/scottalford75/Remora-RT1052/tree/dev
— Four FlexPWMs
Time to create page: 0.562 seconds
