- Hardware & Machines
- Computers and Hardware
- LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
- Zayoo
- Thank you received: 10
17 Dec 2024 10:03 - 17 Dec 2024 10:28 #316845
by Zayoo
Replied by Zayoo on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Thank you meister.
So if I understand well, I may add this modifier to each pin to control it's state in case of error, estop.
Edit:
I did quick test, yes that's solve my issue. Thank you.
Only thing hire is missing one good in depth help file!
Edit:
Last edit: 17 Dec 2024 10:28 by Zayoo.
- meister
- Thank you received: 502
17 Dec 2024 10:34 #316847
by meister
Replied by meister on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
programmer and documentation ...
there is still a lot of work to do
BTW: the enable pins of the pwmout / stepdir plugins, automatically have an error stop included
- epineh
- Thank you received: 27
17 Dec 2024 12:22 #316851
by epineh
Replied by epineh on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
So I can run gw_sh from anywhere, I also edited my .bashrc to make the PATH permanent.
Here is the terminal text, it is still saying it cant see the gowin path, interesting the first line saying XDG_RUNTIME_DIR is not set, I have no idea what that is but it doesn't sound good...
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
loading config: riocore/configs/TangNano9K/config.json
loading board: /home/gus/riocore/./riocore/boards/TangNano9K/board.json
rm -rf rio.fs rio.json rio_pnr.json rio.tcl abc.history impl
gw_sh rio.tcl
make: gw_sh: No such file or directory
make: *** [Makefile:34: impl/pnr/project.fs] Error 127
loading: riocore/configs/TangNano9K/config.json
loading board setup: TangNano9K
loading toolchain gowin
writing gateware to: Output/TangNano9K/Gateware
!!! gateware changed: needs to be build and flash |||
WARNING: can not found toolchain installation in PATH: gowin (gw_sh)
example: export PATH=$PATH:/opt/gowin/IDE/bin
writing linuxcnc files to: Output/TangNano9K/LinuxCNC
gw_sh rio.tcl
gw_sh rio.tcl
gw_sh rio.tcl
The following user(s) said Thank You: Ehsan_R
- meister
17 Dec 2024 12:52 #316854
by meister
are you using sudo ??? do not !
go into the Gateware folder:
and type make:
then type (to check again):
I am really at a loss
cd Output/TangNano9K/Gatewareand type make:
makethen type (to check again):
gw_shI am really at a loss
- digiex_chris
- Thank you received: 11
17 Dec 2024 15:04 #316867
by digiex_chris
You mentioned /home/user/gowin/IDE/bin, does gw_sh actually exist at that exact path? perhaps tryand make sure gw_sh is in there and has the correct permissions for your user to run it. Also, does the user you're running riocore with have access to all directories and files in that path including the parent directories?
I have had issues with gowin running on Ubuntu 24.04, gowin didn't ship the correct versions of one library they compiled against. which OS are you running on?
Ultimately, if you're using a TangNano9k, I recommend the oss-cad-suite instead of gowin. It has been much easier for me to get working reliably across different linux distributions.
Replied by digiex_chris on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Just checking, I don't mean to offend, but have you tried restarting the computer? Terminals often inherit environment (including path) from processes that spawned them, including login sessions.So I can run gw_sh from anywhere, I also edited my .bashrc to make the PATH permanent.
gw_sh rio.tcl
gw_sh rio.tcl
ls -al /home/user/gowin/IDE/binI have had issues with gowin running on Ubuntu 24.04, gowin didn't ship the correct versions of one library they compiled against. which OS are you running on?
- digiex_chris
17 Dec 2024 15:21 #316868
by digiex_chris
Could you give me an idea about how spiflash works on the pi4? I see gpio 7 and gpio 25 being used. It seems that gpio 7 is chip select 1 for spi0 (also defined as /dev/spidev0.1).
From what I see, it
- disables gpio7 if it's enabled as a gpio
- unloads and reloads spidev and spi_bcm2835
- enables gpio25, and sets it as an output pin, but does not set the value of it. It seems it needs to be low in order to set chip select 1 active.
- does obvious flashrom work
- unloads the same spi drivers.
- enables gpio7 again
- sets both 7 and 25 to inputs
- sets 7 to a value of 1, but since it's an input, does this also set it as an output again?
Using hardware spi on the pi5, I've found success by allowing the hardware spi to manage the chip select pin automatically.
I am having trouble resetting the iceshield fpga to a running state after flashrom uploads the firmware. Can you describe how the reset works on the iceshield? What pin values I should be seeing with an oscilloscope on gpio25 at each stage of spiflash.sh?
Could you also explain why it unloads and reloads the spi drivers at the start, and unload again at the end? Is the pi4 version of riocore using software spi (bit banging) instead of hardware spi?
From what I see, it
- meister
17 Dec 2024 15:42 - 17 Dec 2024 15:47 #316870
by meister
puhhh, too many questions
I don't know all that exactly anymore,
can only say that it works like this on the rpi4.
from memory:
* unexport Flash select from gpi, so the SPIdev can use it by it self
* reload SPIDev to get a defined state (i think without that there were errors if linuxcnc was running before)
* then the FPGA must be in RESET mode (25 = 0)
* running flashrom....
* to get a clean state again, the SPIdev is reloaded (I think this also blocks the select lines otherwise)
* Flash select and FPGA reset to input (7 = input / 25 = input), so the FPGA can boot and can operate the flash select itself
* wait a second (FPGA is booting)
* at the end, the flash select is set to 1 again for safety reasons, as the SPI line is to be used for communication with the FPGA (7 = 1)
from memory:
Last edit: 17 Dec 2024 15:47 by meister.
The following user(s) said Thank You: digiex_chris
- meister
17 Dec 2024 16:08 #316875
by meister
one more thing about the 'pin-modifier', i know it takes some getting used to and the implementation gave me a headache
but it makes the thing enormously flexible and customizable.
list of modifier's: debounce, toggle, invert, onerror, pwm
the modifier's can be set for each input and output pin and also as a pipeline one after the other.
* For example, you can 'dim' an output and either reduce the brightness of an LED or operate a 12V relay with 24V (pwm)
* or set the pwm frequency to 1Hz so that the LED flashes
* suppress interference on inputs with debounce
* or other things that would normally require external hardware components.
i have to admit, i'm a bit proud of the function ;P
The following user(s) said Thank You: Zayoo
- digiex_chris
17 Dec 2024 17:38 #316878
by digiex_chris
This helps a lot for my understanding, and I think it explains the error in my python script. I'll change it to configure chip select at runtime instead of at boot time. My pi5 must be holding the state of 7 at a value I don't want if I want to allow the fpga to be the master for the eeprom spi.
Thank you, I appreciate your patience with my questions!* at the end, the flash select is set to 1 again for safety reasons, as the SPI line is to be used for communication with the FPGA (7 = 1)
- digiex_chris
18 Dec 2024 15:17 #316918
by digiex_chris
Anyone can open a PR with updated documentation!Only thing hire is missing one good in depth help file!
Time to create page: 0.393 seconds
