- Hardware & Machines
- Computers and Hardware
- LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
- meister
- Thank you received: 502
- MirkoCNC
09 Dec 2024 13:34 #316334
by MirkoCNC
Replied by MirkoCNC on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
As I have no hardware yet, I am wondering if it is good decision to remove IO_TYPE completely.
It was just my mistake because I have not realized that it can be set within your tool.
The IDE shows me in the Pin Report that all pins are on LVCMOS18 now.
I
I
- MirkoCNC
09 Dec 2024 13:53 #316336
by MirkoCNC
I give up on the portable Python....toolchain. It is easy to use the IDE.
It would be good to have the IO_TYPE back in the pin list and the graphic in the Tab Overview
- MirkoCNC
09 Dec 2024 14:36 #316337
by MirkoCNC
I do not know why, but Tab Overview shows graphic again.
IO_TYPE is better to have back, please
- digiex_chris
- Thank you received: 11
09 Dec 2024 14:44 #316338
by digiex_chris
Replied by digiex_chris on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
@meister have you done any investigation on running the iceshield on a rpi5? it seems the spi and gpio hardware is different. I am unable to get a clock signal on pin 7, it seems like it was not a well supported feature. I used an rp2040 to generate a clock signal instead, wired to pin 7, and flashed using a pi4, and have the blinking light but I'm getting EMCMOT timeouts from linuxcnc. I suspect the SPI interface is different. It's definitely there, I have the expected /dev/spidev0.1, /dev/spidev0.0 devices. I'd love to use the pi5, it's MUCH faster and has better jitter.
- meister
09 Dec 2024 15:11 #316340
by meister
IO_TYPE, no not at the moment, have to check some things first.
@digiex_chris
i have no RPI5, so i can not test it
i only know that there is a general problem with RPI5 and SPI,
but someone on youtube got it to work with RIO
Replied by meister on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
i have fixed the overview today.I do not know why, but Tab Overview shows graphic again.
@digiex_chris
- meister
09 Dec 2024 15:51 #316345
by meister
ok, IO_TYPE for cst pins are back, but only if it is set to non-default value
- digiex_chris
09 Dec 2024 15:57 #316346
by digiex_chris
ah thank you! Knowing that it's possible is helpful. I will look into it and let you know if there is something we can adjust to make it easy.
- Zayoo
- Thank you received: 10
09 Dec 2024 22:34 #316359
by Zayoo
Replied by Zayoo on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Regarding rpi5 I swap to riocore so there is some changes.
For old rio follow instructions on rio page 11
Here is changes for riocore:
I have a raspberry pi5 and this is the code of how I started the SPI communication of the RPI5 - TangNano9K. (Not yet machine tested)
OS:
# uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
In /dev/
Check do you have listed spidev0.0, should be!
Generate output files as for raspberry pi4. When you have generated them, find the file 'riocomp.c' and open it. In general, you need to find and replace the code responsible for rpi4 SPI communication. You need to swap approximately 4200 lines of code with around 60 lines, swap FROM:
INSERT CODE:
TO:
Find and add:
And that's all. This procedure with 'riocomp.c' must be repeated every time the output files are regenerated.
OS:
- LinuxCNC 2.9.2 Raspberry Pi 5 OS based on Debian Bookworm Raspberry Pi 5 Uspace compatible with Mesa Ethernet and SPI interface boards.
#dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
In /dev/
interface: SPI
*/INSERT CODE:
#include <linux/spi/spidev.h>
#include <sys/ioctl.h>
int spifd;
static uint8_t mode = SPI_MODE_0;
static uint8_t bits = 8;
static uint32_t speed = 1500000;
int spi_init(void) {
rtapi_print("Info: Initialize SPI5 connection\n");
spifd = open("/dev/spidev0.0", O_RDWR);
if (spifd < 0) {
rtapi_print_msg(RTAPI_MSG_ERR,"Failed to open SPI device\n");
return -1;
// Set SPI mode
if (ioctl(spifd, SPI_IOC_WR_MODE, &mode) == -1) {
rtapi_print_msg(RTAPI_MSG_ERR,"Failed to set SPI mode\n");
close(spifd);
return -1;
// Set bits per word
if (ioctl(spifd, SPI_IOC_WR_BITS_PER_WORD, &bits) == -1) {
rtapi_print_msg(RTAPI_MSG_ERR,"Failed to set bits per word\n");
close(spifd);
return -1;
// Set max speed
if (ioctl(spifd, SPI_IOC_WR_MAX_SPEED_HZ, &speed) == -1) {
rtapi_print_msg(RTAPI_MSG_ERR,"Failed to set max speed\n");
close(spifd);
return -1;
int spi_trx(uint8_t *txBuffer, uint8_t *rxBuffer, uint16_t size) {
struct spi_ioc_transfer tr = {
.tx_buf = (uint64_t)txBuffer,
.rx_buf = (uint64_t)rxBuffer,
.len = size,
.speed_hz = speed,
.delay_usecs = 0,
.bits_per_word = bits,
// Perform SPI transfer
if (ioctl(spifd, SPI_IOC_MESSAGE(1), &tr) == -1) {
rtapi_print_msg(RTAPI_MSG_ERR,"Failed to perform SPI transfer\n");
return 1;
}TO:
int interface_init(void) {
spi_init();
hal functions
*/Find and add:
//ADD to rtapi_app_exit ->> close(spifd);
void rtapi_app_exit(void) {
close(spifd);
hal_exit(comp_id);
}And that's all. This procedure with 'riocomp.c' must be repeated every time the output files are regenerated.
- meister
10 Dec 2024 08:03 #316381
by meister
Many thanks Zayoo !
i have add the code to the dev branch for testing.
if you want to use it, you can addto your json config
like this:
"rpi5": true,like this:
"name": "IceShield",
"description": "RIO-IceShield on Raspberry PI5",
"boardcfg": "IceShield",
"protocol": "SPI",
"rpi5": true,
The following user(s) said Thank You: digiex_chris
