Rigid Tapping Help
- NCPatrol
The index wires are connected as:
Out Z+ to pin 23 (IDX5)
Out Z- to pin 24 (/IDX5)
This is to "Encoder 5" on the 7i77
- Thank you received: 5334
halmeter signal spindle-index-enable
halcmd sets spindle-index-enable 1
and hand rotate the spindle a full turn, if spindle-index-enable never gets cleared, the hardware is not seeing the index pulse and the signals need to be checked.
A quick way to check differential signals is to measure across the pairs with a voltmeter (that is to check IDX5, measure between TB4 pins 23,24 (IDX5, /IDX5) in both states of index
- NCPatrol
PCW wrote: Can you try this: (from a command line when LinuxCNC is running)
I'll give this a shot tomorrow, but....
I'm a linux moron - is that a command line within linuxCNC or just a linux command line?
What am I looking for when measuring pins 23/24? A change in voltage when index hits?
2. There should be from 2 to 5 V across pins 23 and 24 and the polarity should reverse when index is hit (that is, if you measured +3V across the pins when off index, you should read -3V when on index)
PCW wrote: halmeter signal spindle-index-enable
Actually needs to be
I think. At least I always loadusr halmeter rather than calling it directly.
