Rigid Tapping Help
8 years 3 months ago #114773 by NCPatrol
Replied by NCPatrol on topic Rigid Tapping Help
Bump!
Any pointers?
The previous owner did this conversion with the original steppers and then later converted to servos. He's fairly confident that he had used rigid tapping after the servo conversion (meaning the config should be correct), but I don't think he was 100% sure.
8 years 3 months ago - 8 years 3 months ago #114808 by OT-CNC
Replied by OT-CNC on topic Rigid Tapping Help
I glanced over the ini and hal and didn't see anything obviously wrong but maybe one of the experts could confirm.
How low of an rpm can you go with your vfd?
Seems the encoder is not registering the index signal....but is registering rotation/rpm. More trouble shooting tomorrow!
Can you currently turn on the spindle in a cw and ccw direction?
Can you confirm that in halmeter if you load the encoder.05 it's counting + and -?
Can you turn the spindle manually very slowly and see if the encoder.05 index led blips brown/yellow one per revolution? If you can't turn it slowly you'll need to use halscope to trigger it.
Your ini's name suggests this is on a Boss5 BP type of machine? Can tell us where the encoder is fitted on your machine? Is the vari-disc "gear box" in place and being used? If so, is your spindle at speed correct?
Last edit: 8 years 3 months ago by OT-CNC. Reason: format
8 years 3 months ago #114809 by NCPatrol
OT-CNC wrote: I glanced over the ini and hal and didn't see anything obviously wrong but maybe one of the experts could confirm.
It doesn't seem to like anything below 100rpm, but does fine on the next click up around 120rpm.
Yes, spindle functions perfectly in both directions.
Yes, encoder counts both directions
No change/response shown on any of the index variables.
Correct, it's a rigid ram Boss 5. Encoder is mounted on top of the spindle pulley. The machine has been retrofitted with pulley drives, the varispeed is long gone. Speed appears to be correct, though i haven't checked it with a tach yet. I ha no reason to believe it's off.
8 years 3 months ago #114813 by OT-CNC
How is the encoder connected to your board? Index going to the right connection?
8 years 3 months ago #114815 by NCPatrol
It's a 7i77 and I haven't made any changes to the wiring, so assuming it was set up properly when I brought it home, it should be.
Is there an easy way to test the index signal or would I need a scope?
8 years 3 months ago - 8 years 3 months ago #114817 by OT-CNC
Let's not assume.
You are telling us you are not reading an index pulse. Let's rule out the wiring. Check with the manual to see if the index wire goes to the correct physical pin on the board.
Last edit: 8 years 3 months ago by OT-CNC. Reason: expanded
Time to create page: 3.763 seconds
