Rigid Tapping Help
8 years 3 months ago #115109
Replied by andypugh on topic Rigid Tapping Help
The gearchange component, as far as I know, doesn't do anything at all with the encoder signals. It is purely about scaling the speed request to the VFD.
- OT-CNC
- Thank you received: 75
8 years 3 months ago #115143
by OT-CNC
Replied by OT-CNC on topic Rigid Tapping Help
How about scaling the encoder? Is there anything I need to be aware of in using the scale component for this application, scaling index?
linuxcnc.org/docs/html/man/man9/scale.9.html
Andy, I'm re-posting my question on 33.1 as I'm still looking for clarification:
Andy, there isn't currently a peck tap cycle correct? You just repeat the 33.1 code with different z depths?
Also, if using a tension only tapping head, is there a way to feed in at say 95% and retract at 100% of the pitch? I don't see anything in the docs about that.
Also, in the G code, do we need to call out anything before the g33.1 such as getting out of CSS in lathe mode or setting it to back to ipm mode etc before or after the 33.1? Or does that stay modal? Last, how does the motion planner affect threading? Do we need to get to exact path mode or does G64 path blending not affect rigid tapping? So far I have done it on my lathe but would like to know if I need to call out any important codes before or after 33.1.
Thank you
Thank you
8 years 3 months ago #115144
You can do this with a scale component fed from a mux2 component switched by gear position.
Or, possibly, by using a mux2 to set the encoder.scale to two different numbers.
It might be possible to use gearchange rather than mux2 for this, I don't know if that would be advantageous.
You can't scale the index. It isn't worth trying.
You would need to scale the input to motion.spindle-revs. That should be all that is needed.OT-CNC wrote: How about scaling the encoder? Is there anything I need to be aware of in using the scale component for this application, scaling index?
Yes, that is correct.Andy, there isn't currently a peck tap cycle correct? You just repeat the 33.1 code with different z depths?
Not as far as I know.does G64 path blending not affect rigid tapping?
- Mike_Eitel
- Thank you received: 183
8 years 3 months ago - 8 years 3 months ago #115153
by Mike_Eitel
Replied by Mike_Eitel on topic Rigid Tapping Help
M5C
When U use a encoder plus a comp element and use as input your real encoder index signal than you should be able to uses encoder.index-enable as simulated/divided index puls...
The Idea ist similar to TTL using counter with Reset as a divided..
Or easier do it in a small comp.
Mike
Mike
Last edit: 8 years 3 months ago by Mike_Eitel.
- verticalperformance
- Thank you received: 11
8 years 2 months ago #116601
by verticalperformance
Replied by verticalperformance on topic Rigid Tapping Help
I've used the gearchange function with a sherline mill with a two speed pulley. the "gearchange" is affected manually by a glade UI button (High Speed Pulley in screen grab), but I see no reason why that would not work with a physical sensor that detects which pulley the belt is on. (or gearbox setting etc)
As the encoder is directly on the spindle shaft, all the gearchange is doing on the sherline is scaling the speed bar graph in the GUI, but it is a reasonable example of what the function does.
Few fragments of code (hopefully not missing anything important), the HAL files get their scaling parameters from the .ini file BTW and a screen grab of the relevant bit of the axis GUI
.ini file fragment
Spindle.hal
sherline-mill-gVCP.hal
And the python handler
.ini file fragment
# Spindle Control section
[SPINDLE]
# High Gear
MAX_RPM_HIGH = 3000
GEAR_RATIO = 2
# Low Gear
SCALE_LOW = 1650
OFFSET_LOW = 0.035
MAX_RPM_LOW = 1500
# Spindle at Speed tolerance (RPM)
TOLERANCE = 200
# Preset Speeds for GUI
S1 = 400
S2 = 1000
S3 = 2800
# Hardware Abstraction Layer section
[HAL]
# The run script first uses halcmd to execute any HALFILE
# files, and then to execute any individual HALCMD commands.
# list of hal config files to run through halcmd
#+ files are executed in the order in which they appear
HALFILE = stepper_xyza.hal
HALFILE = standard_pinout.hal
HALFILE = Spindle.hal
HALFILE = manualtoolchange.hal
POSTGUI_HALFILE = sherline-mill-gVCP.hal
Spindle.hal
# Spindle Control File
loadrt abs count=1
loadrt pwmgen output_type=0
# spindle speed feedback
loadrt encoder num_chan=1
loadrt lowpass count=1
loadrt mult2 count=1
loadrt near
loadrt gearchange
# base thread
addf pwmgen.make-pulses base-thread
addf encoder.update-counters base-thread
#servo thread
addf abs.0 servo-thread
addf encoder.capture-position servo-thread
addf lowpass.0 servo-thread
addf near.0 servo-thread
addf mult2.0 servo-thread
addf gearchange.0 servo-thread
#Spindle Control
net spindle-enable <= motion.spindle-on => pwmgen.0.enable
net spindle-cmd <= motion.spindle-speed-out => gearchange.0.speed-in
net spindle-cmd-scaled <= gearchange.0.speed-out => pwmgen.0.value
net spindle-pwm <= pwmgen.0.pwm
#Spindle Speed Scaling
setp pwmgen.0.pwm-freq 5
setp gearchange.0.min1 0
setp gearchange.0.max1 [SPINDLE]MAX_RPM_LOW
setp gearchange.0.min2 0
setp gearchange.0.max2 [SPINDLE]MAX_RPM_HIGH
setp gearchange.0.scale2 [SPINDLE]GEAR_RATIO
setp pwmgen.0.scale [SPINDLE]SCALE_LOW #low gear
setp pwmgen.0.offset [SPINDLE]OFFSET_LOW #low gear
setp pwmgen.0.dither-pwm true
#Spindle Feedback
setp encoder.0.position-scale 6.000000
setp encoder.0.counter-mode 1
# report our revolution count to the motion controller
net spindle-position encoder.0.position => motion.spindle-revs
net spindle-velocity encoder.0.velocity => motion.spindle-speed-in
net spindle-phase-a encoder.0.phase-A
setp lowpass.0.gain 0.01
net spindle-velocity => lowpass.0.in
net spindle-fb-filtered <= lowpass.0.out
net spindle-fb-filtered mult2.0.in1
net spindle-fb-rpm mult2.0.out
setp mult2.0.in0 60
# Test for spindle at speed
net spindle-cmd near.0.in1
net spindle-fb-rpm near.0.in2
net spindle-at-speed motion.spindle-at-speed <= near.0.out
setp near.0.difference [SPINDLE]TOLERANCE #If within 100 RPM
#Connect to physical pins
setp parport.0.pin-01-out-invert 1
net spindle-pwm => parport.0.pin-01-out
setp parport.0.pin-17-out-invert 1
net spindle-enable => parport.0.pin-17-out
net spindle-phase-a <= parport.0.pin-15-in-not
# create a 'estop-is-deactivated' signal
loadrt not count=3 #names=not.0,not.1
addf not.0 servo-thread
addf not.1 servo-thread
addf not.2 servo-thread
net estop halui.estop.is-activated => not.0.in
# and activate the settings box when estop is off
#net estop-inactive not.0.out => gladevcp.settings
# activate the spindle HAL table and all its children when the machine is on
net machine-on halui.machine.is-on => gladevcp.spindle => gladevcp.pulley
net machine-on => gladevcp.preset-speeds
# **** Setup of spindle speed display using glade -START ****
# **** Use ACTUAL spindle velocity from spindle encoder
# **** spindle-velocity is signed so we use absolute component to remove sign
net spindle-fb-rpm => abs.0.in
net spindle-fb-abs-rpm abs.0.out => gladevcp.spindle-rpm-hbar
net spindle-fb-abs-rpm => gladevcp.spindle-speed
net spindle-cmd => gladevcp.spindle-commanded-speed
# **** set up spindle at speed indicator ****
net spindle-at-speed => gladevcp.spindle-at-speed-led
# Link the gearchange to the pulley button
net gearchange-cmd <= gladevcp.high_speed_pulley => gearchange.0.sel
import os,sys
from gladevcp.persistence import IniFile,widget_defaults,set_debug,select_widgets
import hal
import hal_glib
import gtk
import glib
import linuxcnc
import time
debug = 1
c = linuxcnc.command()
s = linuxcnc.stat()
config_ini_file = linuxcnc.ini(os.getenv("INI_FILE_NAME"))
axes = int(config_ini_file.find("TRAJ", "AXES") or 0)
def all_axes_homed():
print "axes: %i" % axes
axes_home= s.homed
print axes_home
print axes_home.count(1)
if axes_home.count(1) == axes:
print ("All axes homed")
return 1
else:
print ("At least one axes is not homed")
return 0
def ok_for_mdi():
s.poll()
print ("OK for MDI Mode")
print ("estop: %i" % s.estop)
print ("enabled: %i" % s.enabled)
print ("interp_state: %i" % s.interp_state)
return not s.estop and s.enabled and all_axes_homed() and (s.interp_state == linuxcnc.INTERP_IDLE)
def ok_for_manual():
s.poll()
print ("OK for Manual Mode")
print ("task_mode: %i" % s.task_mode)
return not s.estop and s.enabled and (s.interp_state == linuxcnc.INTERP_IDLE) and (s.task_mode <> linuxcnc.MODE_AUTO)
class HandlerClass:
class with gladevcp callback handlers
S1 = 0
S2 = 0
S3 = 0
def on_pulley_toggled(self,widget,data=None):
if widget.get_active():
self.builder.get_object('spindle-rpm-hbar').max = float(self.max_speed_high_gear)
else:
self.builder.get_object('spindle-rpm-hbar').max = float(self.max_speed_low_gear)
self.builder.get_object('spindle-rpm-hbar').queue_draw()
self.spindle_rpm_hbar_max = self.builder.get_object('spindle-rpm-hbar').max
print "Toggle Pulley"
def on_stop_clicked(self,widget,data=None):
c.spindle(0)
print "Stop Clicked"
def on_s1_clicked(self,widget,data=None):
if ok_for_mdi():
c.mode(linuxcnc.MODE_MDI)
c.wait_complete() # wait until mode switch executed
c.mdi("M3 S%d" % self.S1)
print "S1: M3 S%d" % self.S1
def on_s2_clicked(self,widget,data=None):
if ok_for_mdi():
c.mdi("M3 S%d" % self.S2)
print "S2: M3 S%d" % self.S2
def on_s3_clicked(self,widget,data=None):
if ok_for_mdi():
c.mdi("M3 S%d" % self.S3)
print "S3: M3 S%d" % self.S3
def on_destroy(self,obj,data=None):
self.ini.save_state(self)
def __init__(self, halcomp,builder,useropts):
Handler classes are instantiated in the following state:
- the widget tree is created, but not yet realized (no toplevel window.show() executed yet)
- the halcomp HAL component is set up and the widhget tree's HAL pins have already been added to it
- it is safe to add more hal pins because halcomp.ready() has not yet been called at this point.
after all handlers are instantiated in command line and get_handlers() order, callbacks will be
connected with connect_signals()/signal_autoconnect()
The builder may be either of libglade or GtkBuilder type depending on the glade file format.
self.halcomp = halcomp
self.builder = builder
self.useropts = useropts
self.max_speed_high_gear = float(config_ini_file.find("SPINDLE", "MAX_RPM_HIGH") or 0.0)
self.max_speed_low_gear = float(config_ini_file.find("SPINDLE", "MAX_RPM_LOW") or 0.0)
self.S1 = float(config_ini_file.find("SPINDLE", "S1") or 100.0)
self.S2 = float(config_ini_file.find("SPINDLE", "S2") or 1000.0)
self.S3 = float(config_ini_file.find("SPINDLE", "S3") or 2800.0)
spindle_S1=self.builder.get_object('hal_spindle_s1')
spindle_S2=self.builder.get_object('hal_spindle_s2')
spindle_S3=self.builder.get_object('hal_spindle_s3')
spindle_S1.set_label("%d RPM" % self.S1)
spindle_S2.set_label("%d RPM" % self.S2)
spindle_S3.set_label("%d RPM" % self.S3)
print "High Gear: %d" % self.max_speed_high_gear
print "Low Gear: %d" % self.max_speed_low_gear
self.defaults = {
IniFile.vars : { 'spindle_rpm_hbar_max' : self.max_speed_high_gear},
IniFile.widgets: widget_defaults(select_widgets(self.builder.get_objects(), hal_only=True,output_only = True))
self.ini_filename = __name__ + ".ini"
print "Ini File Name: %s" % self.ini_filename
self.ini = IniFile(self.ini_filename,self.defaults,self.builder)
self.ini.restore_state(self)
self.builder.get_object('spindle-rpm-hbar').max= float(self.spindle_rpm_hbar_max)
def get_handlers(halcomp,builder,useropts):
this function is called by gladevcp at import time (when this module is passed with '-u <modname>.py')
return a list of object instances whose methods should be connected as callback handlers
any method whose name does not begin with an underscore ('_') is a callback candidate
the 'get_handlers' name is reserved - gladevcp expects it, so do not change
return [HandlerClass(halcomp,builder,useropts)]
The following user(s) said Thank You: OT-CNC
- gmarconi2
- Thank you received: 5
7 years 7 months ago #129283
by gmarconi2
Replied by gmarconi2 on topic Rigid Tapping Help
I happened by chance here, but the error is a comma instead of the point in the first post N445 line
instead of G43 Z0.6 H2 changes to G43 Z0.6 H2
Hi gmarconi2
Hi gmarconi2
Time to create page: 3.904 seconds
