Rigid Tapping Help
8 years 3 months ago - 8 years 3 months ago #114896 by PCW
Replied by PCW on topic Rigid Tapping Help
halmeter and halshow run fine directly from the command line...
(at least in this case where LinuxCNC is already running )
Last edit: 8 years 3 months ago by PCW.
8 years 3 months ago #114955 by NCPatrol
Replied by NCPatrol on topic Rigid Tapping Help
OK, so "halmeter signal spindle-index-enable" pops up the hal meter window
and "halcmd sets spindle-index-enable 1" doesn't appear to do anything.
The hal meter initially shows "true" when the window pops up and changes to "false" when I rotate the spindle by hand. It stays false after that.
Probing pins 23/24 I see ~2.5v and it doesn't change when I rotate the spindle slowly.
Is it safe to assume that my encoder is shot? I've been hesitant to throw another $90 at an encoder without some verification, but if this is it, I'll get one ordered.
8 years 3 months ago #114956 by andypugh
Replied by andypugh on topic Rigid Tapping Help
NCPatrol wrote: The hal meter initially shows "true" when the window pops up and changes to "false" when I rotate the spindle by hand. It stays false after that
Is it safe to assume that my encoder is shot?.
On the contrary, it shows that everything is working properly.
(You should find that if you set the index-enable to true that it sets to zero again at exactly the same spot in the spindle rotation, and that is the point of it. LinuxCNC motion looks for the index-enable resetting to false to start the spindle-synched move.
8 years 3 months ago #114964 by NCPatrol
So why no =/- change on the pins when rotating?
And I guess, if the hal indicates the sensor itself is working, where do I go from here?
8 years 3 months ago #114965 by andypugh
The encoder index pulse might just be too short to see in halmeter (it might b a fixed-length pulse).
Now we know that the hardware is good, can you remind us what the problem is?
8 years 3 months ago #114966 by andypugh
Can you check the question I asked earlier?
Does the encoder count up in M3 and down in M4 mode?
Time to create page: 0.352 seconds
