Probe panel for Axis GUI
  • Aciera
  • Administrator
  • Administrator
2 years 5 months ago - 2 years 5 months ago #302043 by Aciera
Replied by Aciera on topic Probe panel for Axis GUI
What version of LinuxCNC are you running?
Any errors when launching from a terminal?
[edit]
Also, try the 'sim/pyvcp_demo/pyvcp_embed_tab' from the config picker. Does that work for you?
Last edit: 2 years 5 months ago by Aciera.
2 years 5 months ago #302045 by handsomebeast
Replied by handsomebeast on topic Probe panel for Axis GUI
get no errors when running from a terminal im running debian 10 buster (linux debian 4.19.0-25-rt-amd64 #1 SMP PREMPT RT debian 4.19.289-2
i dont have that config in my configs folder,
  • Aciera
  • Administrator
  • Administrator
2 years 5 months ago #302047 by Aciera
Ok, so it seems that pyvcp tab embedding was added rather recently. So it looks like you would have to update to the current 2.9.x.
github.com/LinuxCNC/linuxcnc/commit/a343...d4652c1be3f35c8b8545
2 years 4 months ago #302110 by handsomebeast
upgraded to 2.9.2. now spindle and probe dont appear at all or classicladder.
2 years 4 months ago - 2 years 4 months ago #302126 by handsomebeast
ok thanks for the help aciera, was testing this out in a vm to mak sure i was doing everything right before installing onto my machine that runs my router, which is on debian 10 , 2.8.4 prempt rt, which i now find is for mesa card, but im running a 5 axis parrall breakout board and was just on th edge with latency, anyways got my machine config fils to work on the new debian 12 2.9.2 bookworm preempt rt. classicladder and the panel are showing up now, but the probe panel, i cant see the green probe indicator but i think i need to change the size of the buttons in the xml file, now the problem is the tutorial is very confusing, firstly without your suggestion to the embdded tab, it wouldnt show up in 2.9.2. and the rest of the tutorial i cannot follow, on one of the pics of the probe panel the spindl, stop ,and probe are in tabs on the right and this would be perfect so i could see the preview in that configuration,
Last edit: 2 years 4 months ago by handsomebeast.
  • Aciera
  • Administrator
  • Administrator
2 years 4 months ago #302127 by Aciera
Which tutorial are you referring to?
Time to create page: 0.153 seconds
