Probe panel for Axis GUI
- ckuecker
2 years 11 months ago #285327
by ckuecker
Replied by ckuecker on topic Probe panel for Axis GUI
All that is in the .ini file. Cut and pasted.
- cakeslob
- Thank you received: 280
2 years 11 months ago #285339
by cakeslob
Replied by cakeslob on topic Probe panel for Axis GUI
Im no expert, but probably this in the ini
probably should be something like this
[HALUI]
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XYZ
MDI_COMMAND = G54
MDI_COMMAND = G55
MDI_COMMAND = G56
MDI_COMMAND = G57
MDI_COMMAND = G58
MDI_COMMAND = G59
MDI_COMMAND = G59.1
MDI_COMMAND = G59.2
MDI_COMMAND = G59.3
MDI_COMMAND = G10 L20 P0 X0
MDI_COMMAND = G10 L20 P0 Y0
MDI_COMMAND = G10 L20 P0 Z0
MDI_COMMAND = O <probe_toolchange> CALL [1]
MDI_COMMAND = O <probe_toolchange> CALL [2]
MDI_COMMAND = O <probe_toolchange> CALL [3]
MDI_COMMAND = O <probe_x_plus> CALL
MDI_COMMAND = O <probe_x_minus> CALL
MDI_COMMAND = O <probe_y_plus> CALL
MDI_COMMAND = O <probe_y_minus> CALL
MDI_COMMAND = O <probe_z_minus> CALL
MDI_COMMAND = O <probe_pocket> CALL
MDI_COMMAND = O <probe_calibration> CALL
[HALUI]
MDI_COMMAND = G54
MDI_COMMAND = G55
MDI_COMMAND = G56
MDI_COMMAND = G57
MDI_COMMAND = G58
MDI_COMMAND = G59
MDI_COMMAND = G59.1
MDI_COMMAND = G59.2
MDI_COMMAND = G59.3
[KINS]
JOINTS = 3
The following user(s) said Thank You: tommylight, ckuecker
- ckuecker
2 years 11 months ago #285376
by ckuecker
That did it! Thanks!
I'm just beginning to learn the syntax of hal and G-code. Spent the last 30+ years doing microprocessor assembly and C.
- ckuecker
2 years 11 months ago #285379
by ckuecker
Playing with the probe panel - man page says to calibrate each tool before use - activated calibration button - clicked it - nothing happens.
Man page says to follow LinuxCNC messages - where do I find these?
- ckuecker
2 years 11 months ago #285381
by ckuecker
Found the message - need to select the tool first - get message "no tool, aborting"
Looks like something is getting stuck in a loop - select tool 1, enable calibration - now I can't jog any axis. Have to exit LinuxCNC and restart to get control back.
- ckuecker
2 years 11 months ago #285435
by ckuecker
One more note - if I enable calibration, the MDI panel is inactive, and can't be recovered without restarting LinuxCNC.
Time to create page: 1.350 seconds
