- Thank you received: 2177
Probe panel for Axis GUI
2 years 2 months ago - 2 years 2 months ago #307057
Looks like you are missing the [PROBE] section in your ini file. For an example ini file see:
github.com/hausen8/EasyProbe/blob/v2.0/m...y_Probe_2.0_demo.ini
Disregard
Replied by Aciera on topic Probe panel for Axis GUI
Disregard
Last edit: 2 years 2 months ago by Aciera.
- juliankoenig87
- Thank you received: 55
2 years 2 months ago #307072
by juliankoenig87
Replied by juliankoenig87 on topic Probe panel for Axis GUI
He has it at the end of the .ini file.
The error sounds strange and I never had this one.
Other than copy paste the parts again I have no clue.
Julian
Julian
- juliankoenig87
2 years 2 months ago #307073
by juliankoenig87
Maybe another line ending story?
Did you copy it with a windows machine or something like that?
I would type the VEL_FAST... separately with the keyboard. Just in case...
2 years 2 months ago #307074
I notice that there are inline-comments_
I know it has already been suggested to use '#' instead. IIRC there should not be any inline comments in the ini file.
So maybe try:
If that works for VEL_FAST then do the same with all the inline comments.
VEL_FAST = 5 [200 was the original value]
So maybe try:
VEL_FAST = 5
- juliankoenig87
2 years 2 months ago #307075
by juliankoenig87
Ah. You are right..He did not mentioned that he deleted the "[...]".
- TucsonSean
2 years 2 months ago #307079
by TucsonSean
Replied by TucsonSean on topic Probe panel for Axis GUI
I have tried using other commands, find center, find edge, etc... and I get the same error message: Named Parameter #<_ini[probe]vel_fast> not defined
Is there a difference with version 2.8.4 for declaring variables in the ini file versus newer 2.9 versions?
-Sean
-Sean
Time to create page: 0.795 seconds
