- Thank you received: 4
Probe panel for Axis GUI
- handsomebeast
2 years 4 months ago - 2 years 4 months ago #302128
by handsomebeast
Replied by handsomebeast on topic Probe panel for Axis GUI
the one at the beginning of this topicĀ
github.com/hausen8/EasyProbe
Last edit: 2 years 4 months ago by handsomebeast.
- Thank you received: 2177
2 years 4 months ago #302129
Replied by Aciera on topic Probe panel for Axis GUI
Ah, the one where the tabs are in the side panel. That is done in the .xml. Have a look at the file 'AL_1105_panel.xml' here:
github.com/hausen8/AL_1105
I'm sorry I didn't realize that is what you wanted. That would probably have worked with your older version.
- handsomebeast
2 years 4 months ago #302130
by handsomebeast
thankyou i should be abl to figure that out
- handsomebeast
2 years 4 months ago #302243
by handsomebeast
tried and tried cant get my head around it just get errors and lcnc wont start
2 years 4 months ago #302247
That is not much information to go by, I'm afraid. If errors come up while starting the config then it is usually a good idea to post those. Also posting your current config as a zipped folder saves helpers from just poking in the dark.
Generally I would suggest this approach:
1. try to just simply copy and paste the 'AL_1105_panel.xml' to your config and load that using
PYVCP = AL_1105_panel.xml
2. if that works you may want to rename the .xml
3. start connecting the individual panel elements in the postguihal while frequently testing that the config still starts up.
4. If you need/want to edit the .xml make sure to take small steps and test frequently, as it is rather easy to break something.
- handsomebeast
2 years 4 months ago - 2 years 4 months ago #302263
by handsomebeast
thankyou aceira, ive made some progress, got the easy probe and spindle panels into seperate tabs like the picture, followeed thee rest of the tutorial and got a few errors i thought id reesolve but when i tried it on the machine the probe tab does nothing at all, idk wether its because my probe is nc and thereees a -not i need to add somewhere or what. but its a steep in the right direction and it also works on 2.8.2 buster which mans i dont need to upgrade to 2.9 as it only has PREEMPT RT which is suited to mesa card and im using a 5 axis breakout paralell board. ive linked my files if anyone can tell m where im going wrong, btw the probes are wired NC, the tool setter is NC and the touch probe is NO but it has a physical relay wired before the toolsetter to make the touch probe NC until triggeeered so i can leave both connected permanently asd use th same input for both as i havee no more inputs on my BOB
Time to create page: 0.170 seconds
