Probe panel for Axis GUI
2 years 4 months ago #303730 by handsomebeast
Replied by handsomebeast on topic Probe panel for Axis GUI
ok M61 Q99 solves that problem all good for now
thanks again for the help guys
2 years 2 months ago #306991 by TucsonSean
Replied by TucsonSean on topic Probe panel for Axis GUI
Hello Gentlemen,
I have encountered an issue with my installation of EasyProbe. After installation, I have taken care of all errors and was able to start LinuxCNC and when I go to calibrate the probe, I get the following error: Named Parameter #<_ini[probe]vel_fast> not defined
I know that vel_fast was a variable copied directly from the installation instructions and placed into the ini file.  Any help pointing me in the right direction would be greatly appreciated.
-Sean
LinuxCNC ver: 2.8.4
2 years 2 months ago #307016 by juliankoenig87
Replied by juliankoenig87 on topic Probe panel for Axis GUI
Hi.
Please show your .ini and your .hal files. There must be a wrong typing or something like that.
Julian
2 years 2 months ago #307027 by TucsonSean
Here are my hal and ini files.
-Sean
File Name: Probe_preload.hal
File Size:1 KB
File Name: Probe_postgui.hal
File Size:8 KB
File Name: Taig_Mill_7i92.ini
File Size:9 KB
File Name: Taig_Mill_7i92.hal
File Size:13 KB
2 years 2 months ago #307038 by juliankoenig87
Two things.
First of all delete everthing before the MDI command for G54. So delete(pr comment out):
MDI_COMMAND=...
MDI_COMMAND=...
MDI_COMMAND=...
MDI_COMMAND=...
MDI_COMMAND=...
MDI_COMMAND=...
MDI_COMMAND=G10 L20 P1 X0MDI_COMMAND=G10 L20 P1 Y0
MDI_COMMAND=G10 L20 P1 Z0
MDI_COMMAND=G0 X0
MDI_COMMAND=G0 Y0
MDI_COMMAND=G0 Z0
The mdi commands haveto be in the right order like in the hal.
Second. Delete the "[...]" after the parameters in your ini. Or use "#" for comments.
Julian
2 years 2 months ago #307049 by TucsonSean
I deleting everything before the G54 command and edited the Probe_Postgui.hal file to reflect the changes. When I start LinuxCNC, I still get the error: Named Parameter #<_ini[probe]vel_fast> not defined
Is there something that I am missing for declaring the vel_fast variable in the .ini file other than what I copied and pasted from the instructions?
-Sean
Time to create page: 1.473 seconds
