Probe panel for Axis GUI
2 years 2 months ago #307080 by Aciera
Replied by Aciera on topic Probe panel for Axis GUI
can you please post your current hal and ini files?
2 years 2 months ago #307081 by TucsonSean
Replied by TucsonSean on topic Probe panel for Axis GUI
IT WORKS!
I deleted the offending lines of text (supposed to be comments but I forgot the # ) from the ini file and it worked. My mill is calibrating my probe as I type this.
Thank you for your assistance in getting this working. Really appreciate the help.
-Sean
2 years 2 months ago #307082 by tommylight
Replied by tommylight on topic Probe panel for Axis GUI
[EMC] MACHINE = MAZAK_Micro_Slant_15 DEBUG = 0 VERSION = 1.1 [DISPLAY] DISPLAY = axis POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL MAX_FEED_OVERRIDE = 2.000000
Square brackets are used to separate sections of the ini file so they can not be used as comments.
# <<< this should be OK, most probably
The following user(s) said Thank You: TucsonSean
2 years 2 months ago #307084 by juliankoenig87
Replied by juliankoenig87 on topic Probe panel for Axis GUI
Easyprobe should work from 2.6 on (valutransformations in the messages) if I am right.
I wrote the most parts with 2.8.4 an finally with 2.9.2.
Julian
2 years 2 months ago #307094 by TucsonSean
I tried using 2.7 and I kept getting dbounce error and LinuxCNC would not load. I upgraded to 2.8.4 and I did not get the dbounce error any longer.
2 years 2 months ago - 2 years 2 months ago #307095 by TucsonSean
Ok, two more questions:
First, what is the procedure for using this with a machine set to inches for the units?  I have converted the mm values to inches in the ini files but are there other values that need to be adjusted in other files?
Second, the calibration completes and enters the data into the tool table (I checked the file and there are now X, Y, I and J values added to Tool 99). When I try to do any other probing operatoin, i get the following error: No calibration data found in tool table. Please do a calibration. aborting
I re-ran calibration and now it is working.
So, my first question still stands.
-Sean
Last edit: 2 years 2 months ago by TucsonSean.
Time to create page: 0.139 seconds
