5Axis Kinetic from 2.8 on 2.7x
6 years 2 months ago #180157 by JackRay
Replied by JackRay on topic 5Axis Kinetic from 2.8 on 2.7x
Good morning all ,
Probably basic question ...
Can I do 5 axes simultaneously with the linuxCNC 2.7.14 version? Or do I have to go through version 2.8?
I am having too much trouble updating my CNC control computer.
It is under Dabian GNU. the "Update" / "Upgrate" no longer want to be done.
Thank you for your help
6 years 2 months ago #180165 by tommylight
Replied by tommylight on topic 5Axis Kinetic from 2.8 on 2.7x
As far as i know, yes.
The following user(s) said Thank You: JackRay
6 years 2 months ago #180178 by JackRay
Hello ,
what should I put in should I change in my .hal & .ini files?
Thank you
6 years 2 months ago - 6 years 2 months ago #180255 by Aciera
Replied by Aciera on topic 5Axis Kinetic from 2.8 on 2.7x
If you are indeed trying to use kinematics from Version 2.8 in Version 2.7 then you would be better off to invest the time in upgrading your system. It has been stated before that this will not work. Changing your hal and ini files will not solve this.
You might want to have a look at the switchkins branch as it allows you to switch between trivial kinematics to tcp kinematics. This requires a run in place installation though.
www.panix.com/~dgarrett/stuff/switchkins.html
Last edit: 6 years 2 months ago by Aciera.
6 years 2 months ago #180268 by JackRay
Response le 01/09/2020 à Aciera 9h00.
Hello Aciera,
- I understood that the mixture of the two versions was not compatible (post from Rodw).
- it is clear that if I want to do (TCP) I have to go through the "xyzac-trt-kins" module which is only available in version 2.8.
- My problem is that my CNC control computer is 32 bit, so I can only install a 32 bit "OS" and find LinuxCNC 2.8 32bits.
- My Dabian GNU system refuses updates. The links are no longer active.
- Do you know a procedure to reinstall my 32 bit system with LinuxCNC 2.7.14 and then an update with a file (no network) to LinuxCNC 2.8.
I read, that during the update, when starting LinuxCNC 2.8 for the first time the migration was automatic, Linuxcnc 2.8 converted the .hal .ini files from 2.7 to 2.8 and many other things.
- Thank you again for following my misadventures, and for answering all my questions.
But I think the program is superb, I was able to machine some parts in 5 axes and I realized the reliability and precision of the system, it is for this reason that I want to go further.
- In addition the community is great, is available, this is how we move forward and when I have fully developed my machine, I will upload all my "config" files to help like me today people who want to succeed in their projects.
Thank you
6 years 2 months ago #180280 by Aciera
I gather there is a converter to migrate your config from 2.7 to 2.8. I have never used it though.
As to upgrading:
Have you added the repositories to your synaptic package manager as described in the buildbot webpage?
Not sure if there is a way to download the necessary files and copy them to your machine.
Maybe start a new thread about where to find a 32bit ISO with version2.8 that is suitable for parallel port operation. My systems use the Ethernet port and for that latency is less crucial. Also my hardware is 64bit
Time to create page: 0.184 seconds
