- Thank you received: 14
5Axis Kinetic from 2.8 on 2.7x
- JackRay
6 years 1 month ago #181457
by JackRay
Replied by JackRay on topic 5Axis Kinetic from 2.8 on 2.7x
- Thank you received: 2177
6 years 1 month ago #181459
Replied by Aciera on topic 5Axis Kinetic from 2.8 on 2.7x
That error is because you use the same signal names in joint.3.- and joint.4.- sections.
You need to use new signal-names, like this:
setp stepgen.4.position-scale [JOINT_4]SCALE
setp stepgen.4.steplen 1
setp stepgen.4.stepspace 0
setp stepgen.4.dirhold 35000
setp stepgen.4.dirsetup 35000
setp stepgen.4.maxaccel [JOINT_4]STEPGEN_MAXACCEL
net bpos-cmd joint.4.motor-pos-cmd => stepgen.4.position-cmd
net bpos-fb stepgen.4.position-fb => joint.4.motor-pos-fb
net bstep <= stepgen.4.step
net bdir <= stepgen.4.dir
net benable joint.4.amp-enable-out => stepgen.4.enable
The following user(s) said Thank You: JackRay
- JackRay
6 years 1 month ago #181461
by JackRay
Indeed, thank you very much, I had it in front of me, and not even seen. I continue my settings.
thanks again
thanks again
- JackRay
6 years 1 month ago #181563
by JackRay
Hello ,
- I was therefore able to carry out my configuration and run Lcnc 2.8 without error.
- Effectively the emergency stop button and the original socket contacts no longer work with version 2.8.
- However, I checked with "halmetre" and all the signals pass without problem ??? I have communication with my "break out" card.
- If again you can help me, i attach my .hal & .ini file ?
Thank you for your attention
6 years 1 month ago #181565
So does the external emergency stop button fail to stop the machine?
I'm not clear what you mean by " original socket contacts".
Can you start the machine through the gui or does the external emergency stop signal keep the gui in estop?
6 years 1 month ago #181568
You have
and farther down:
This looks a bit odd:
If you have your external estop connected to parport.0.pin-10-in-not then you have not connected the signal estop-ext to anything
also estop-loop parport.0.pin-01-in is commented out
net estop-out => parport.0.pin-01-out
net estop-ext <= parport.0.pin-10-in-not
#net estop-loop parport.0.pin-01-in iocontrol.0.emc-enable-in
and farther down:
net estop-out => iocontrol.0.emc-enable-in
