5Axis Kinetic from 2.8 on 2.7x
6 years 1 month ago #181987 by Aciera
Replied by Aciera on topic 5Axis Kinetic from 2.8 on 2.7x
For that you have to program "M" codes, like "M128" to activate "TCP" & "M129" to deactivate it.
To use those M codes you need a version of LinuxCNC that allows switching kinematics. This functionality has not been merged with the main branch of linuxcnc. So in order to install that you will need to do a RIP (Run in Place) install of dewey garretts switchkins branch. This will require you to compile and build linuxcnc from source.
Here is his guide: www.panix.com/~dgarrett/stuff/s_kins_guide.txt
Further information:
www.panix.com/~dgarrett/stuff/switchkins.html
6 years 1 month ago #182001 by JackRay
Replied by JackRay on topic 5Axis Kinetic from 2.8 on 2.7x
Thank you for all those informations.
I do not have the necessary level to do this (compliation / branch ??).:( :(
however, I saw that I could use the M66 / M68 to change the type of kinematics and synchronization of the axes.
all this with the subroutine call.
subroutine call as I have already used for the automatic measurement of my tool length.
Is it correct ?
Thank you
6 years 1 month ago #182007 by Aciera
M66 and M68 are indeed used in the M128/M129 commands to read/write values from inside the Gcode. However the actual changing of kinematics is only possible if you run the switchkins-branch.
This is, by the way, also why I got to learn how do a RIP install. It's really not all that difficult. One just has to sit down and try.
Really all that's needed is described in the link above:
Warning: Spoiler!
You've got a nice machine, would be a shame.
The following user(s) said Thank You: JackRay
6 years 1 month ago #182009 by JackRay
Thanks, but I'm really not good on linux.
it starts well I do not have the files attached in my tree structure ...
6 years 1 month ago #182010 by JackRay
I got to go until there.
but the error ??
thank you very much, but without you it's impossible to do it.
6 years 1 month ago #182011 by Aciera
Have you completed step 2?
2) To get the source code and build LinuxCNC, see:
linuxcnc.org/docs/master/html/code/building-linuxcnc.html
Learn how to build the default (master) branch first.
You must succeed with this before proceding.
There you need to first try this:
It this fails, as it probably will, you will need to install the missing dependencies.
Maybe this helps: (I have not actually watched the whole thing)
Time to create page: 0.136 seconds
