- Thank you received: 4153
5Axis Kinetic from 2.8 on 2.7x
6 years 1 month ago #182114
Replied by rodw on topic 5Axis Kinetic from 2.8 on 2.7x
Yes, A quick google says to try
See howtoinstall.co/en/ubuntu/xenial/yapps2
So onto the next one.
sudo apt-get install yapps2
The following user(s) said Thank You: JackRay
- JackRay
- Thank you received: 14
6 years 1 month ago #182120
by JackRay
Replied by JackRay on topic 5Axis Kinetic from 2.8 on 2.7x
- Thank you received: 2177
6 years 1 month ago #182179
Replied by Aciera on topic 5Axis Kinetic from 2.8 on 2.7x
try:
sudo apt-get install tcl-dev
6 years 1 month ago #182210
Replied by andypugh on topic 5Axis Kinetic from 2.8 on 2.7x
Installing the 2.8 package should auto-install the dependencies.
(and, to back-track, it should be entirely possible to use the latest kins modules from 2.8 in 2.7 as the kins file format hasn't changed)
But 2.8 is definitely where you want to be for non-trivial kins.
6 years 1 month ago #182218
@Andy
Not sure what you mean. We are trying to install deweys switchkins branch using his how-to: www.panix.com/~dgarrett/stuff/s_kins_guide.txt
Are you saying there is a shorter way to get the dependencies installed?
6 years 1 month ago #182222
Sorry, I am trying to catch up after being distracted for a while.
If you are compiling an experimental branch then you will need the build dependencies.
One less iterative way to get them is:
cd linuxnc-dev
./debian/configure uspace
dpkg-checkbuilddeps
Will list all outstanding build dependencies.
cd linuxnc-dev
dpkg-checkbuilddeps
Time to create page: 0.181 seconds
