- Thank you received: 2177
5Axis Kinetic from 2.8 on 2.7x
6 years 1 month ago #182431
Replied by Aciera on topic 5Axis Kinetic from 2.8 on 2.7x
Well, you didn't follow the instructions.
in the directory ~/linuxcnc-dev/debian$
you need to run the command: ./configure uspace
after that you run: dpkg-checkbuilddeps
- JackRay
- Thank you received: 14
6 years 1 month ago #182450
by JackRay
Replied by JackRay on topic 5Axis Kinetic from 2.8 on 2.7x
6 years 1 month ago - 6 years 1 month ago #182451
Ok, that complicates things. So lets try if we can get the required key installed.
Import the key:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys C9F836336AAD909E
try the update again:
sudo apt-get update
If this does not work we'll go back to dealing with the missing dependencies one by one.
Import the key:
sudo apt-get update
Last edit: 6 years 1 month ago by Aciera.
- JackRay
6 years 1 month ago #182452
by JackRay
it was not complicated enough ...
6 years 1 month ago #182453
Exactly. Looks like BeagleBrainz had forgotten his password and had to change the key.
forum.linuxcnc.org/9-installing-linuxcnc...t-iso?start=0#165631
Lets try and see.
Lets try and see.
- JackRay
6 years 1 month ago #182454
by JackRay
Time to create page: 0.405 seconds
