5Axis Kinetic from 2.8 on 2.7x
6 years 1 month ago #182455 by JackRay
Replied by JackRay on topic 5Axis Kinetic from 2.8 on 2.7x
I do not understand what is happening. the path has disappeared, the update does not change ???
6 years 1 month ago #182473 by tommylight
Replied by tommylight on topic 5Axis Kinetic from 2.8 on 2.7x
Last line should be
sudo apt-add-repository
6 years 1 month ago #182506 by Aciera
Replied by Aciera on topic 5Axis Kinetic from 2.8 on 2.7x
Have you since tried this again:
Warning: Spoiler!
If this still does not work we have these possibities:
1. Keep trying to figure out this update issue, but really I'm running out of ideas here.
2. Go back to installing the dependencies manually as we were before.
3. Make a fresh install of linuxmint without linuxCNC and install LinuxCNC from source using the dpkg-checkbuildeps method.
6 years 1 month ago #182512 by anfänger
Replied by anfänger on topic 5Axis Kinetic from 2.8 on 2.7x
JackRay wrote: I do not understand what is happening. the path has disappeared, the update does not change ???
The reason why this looks fo funny is you forgot a ` at the end of the repository so the Command wasn‘t executed.
6 years 1 month ago #182553 by JackRay
Hello ,
The package "cnc.beaglebrainz.net" could not be updated ...I am trying to install the "libxenomai-dev" package as requested.Exact ?
6 years 1 month ago #182555 by JackRay
Time to create page: 0.162 seconds
