5Axis Kinetic from 2.8 on 2.7x
6 years 1 month ago #182712 by Aciera
Replied by Aciera on topic 5Axis Kinetic from 2.8 on 2.7x
Very good indeed!
So next is
make
and if that works
sudo make setuid
6 years 1 month ago #182713 by JackRay
Replied by JackRay on topic 5Axis Kinetic from 2.8 on 2.7x
What do you think about ?
6 years 1 month ago #182733 by Aciera
If all went well you should be able to start your RIP install:
source ../scripts/rip-environment
cd ..
linuxcnc
Once this works you can go back to this:
Warning: Spoiler!
6 years 1 month ago #182750 by JackRay
I think everything went well, I have no mistakes. I have now a version 2.9.0.
But what should I do.
The goal of all this is to do 5 axes simultaneously.
Thank you again for your help, I didn't understand everything, but I had times where I thought we would not make it
6 years 1 month ago - 6 years 1 month ago #182759 by Aciera
What does this say?
git branch | grep \*
If it says switch-kins then you should have the version that can switch kinematics.
So:
1. copy your machine configuration folder into the folder ~/linuxcnc-dev/config
you should be able to start your machine.
If this works we can continue to setup the switch-kins command.
Remember when you start a new terminal window you have to set you environment again by
cd ~/linuxcnc-dev/src
cd ..
linuxcnc
Last edit: 6 years 1 month ago by Aciera.
6 years 1 month ago #182823 by JackRay
Ok thank you ,
then I do a "Launcher" on my desktop to start version 2.9
Time to create page: 0.228 seconds
