- Thank you received: 14
5Axis Kinetic from 2.8 on 2.7x
- JackRay
6 years 3 weeks ago #184861
by JackRay
Replied by JackRay on topic 5Axis Kinetic from 2.8 on 2.7x
Hello ,
So I try to save my system. I tried to install Systemback but I couldn't. could not find the packets, and file.sh does not install on linuxMint ... I tried Clonezilla, and the disk utility that came with LinuxMint, and still the same thing. it tells me that my source disk is busy.
I do not know how to do. Do you have a solution?
Thanks for your help
- JackRay
6 years 3 weeks ago #184862
by JackRay
As promised, I am attaching my .hal.ini files to you. to get an idea . But before you get there you need to find all the sources to complete them and install a Version 2.9 of LinuxCNC. This version supports "switchkins".
Try to follow the questions / answers we had with Aciera in the forum.
Good Neight
Good Neight
The following user(s) said Thank You: OT-CNC
- Thank you received: 2177
6 years 3 weeks ago #185050
Replied by Aciera on topic 5Axis Kinetic from 2.8 on 2.7x
For cloning my disks I use Clonezilla on a live usb stick. So I plug in my empty target drive and boot clonezilla from usb. Then choose the source disk I want to backup and the target disk to write to (make sure you choose the correct drives here) and start the cloning process. I try to use identical drives otherwise you can run into issues cloning from a larger to a smaller disk (although there are ways to solve that as well)
clonezilla.org/downloads/download.php?branch=stable
The following user(s) said Thank You: JackRay
- JackRay
6 years 3 weeks ago #185273
by JackRay
Hello,
I am doing exactly the same as you, and it works on my laptop PC but not on the CNC machine PC. I have this message.
When do you think ?
Thank you
When do you think ?
Thank you
- JackRay
6 years 3 weeks ago #185276
by JackRay
- Thank you received: 7491
6 years 3 weeks ago #185281
Replied by tommylight on topic 5Axis Kinetic from 2.8 on 2.7x
You are trying to clone one partition to another on the SAME drive !
Please read the instructions on using Clonezilla.
Time to create page: 0.442 seconds
