5Axis Kinetic from 2.8 on 2.7x
5 years 11 months ago - 5 years 11 months ago #190313 by Aciera
Replied by Aciera on topic 5Axis Kinetic de 2.8 en 2.7x
No that won't work. The kinematic has to reflect the axis setup of the machine. But there is a xyzac-trt kinematic in linuxcnc.
linuxcnc.org/docs/2.8/html/motion/5-axis-kinematics.html
If you have a xyzac-trt setup but with a gantry using two motors for the same axis say xyyzac then you will need to adjust the kinematics file and rebuild linuxcnc.
[edit]
This is for changing xyzbc to xyzzbc kinematic but it's the same (fairly straight forward) procedure:
forum.linuxcnc.org/10-advanced-configura...-kins-module?start=0
Last edit: 5 years 11 months ago by Aciera.
  • Profed81
  • Visitor
  • Visitor
5 years 11 months ago #190314 by Profed81
Replied by Profed81 on topic 5Axis Kinetic de 2.8 en 2.7x
In which folder is this configuration for tilting spindle found?
  • Profed81
  • Visitor
  • Visitor
5 years 11 months ago #190315 by Profed81
Build means, compile?
  • Profed81
  • Visitor
  • Visitor
5 years 11 months ago #190317 by Profed81
"Trt" means, tilting table, I need to convert to tilting spindle (srt) Spindle rotating tilting
5 years 11 months ago #190319 by Aciera
Ah, I see, -trt won't work for a tilting head setup. As far as I know Bridgemill is the only kinematic where the spindle does both rotations.
So really in your case it's just that x and y axis are swapped compared to the "bridgemill" simulation?
  • Profed81
  • Visitor
  • Visitor
5 years 11 months ago #190342 by Profed81
In this document it says that it is in the git tree, but what is "git tree?" is that on the internet? Or in some directory on my computer?
This browser does not support PDFs. Please download the PDF to view it: Download PDF
Time to create page: 0.431 seconds
