- Thank you received: 75
5Axis Kinetic from 2.8 on 2.7x
- OT-CNC
There, I have arrived at the goal. I have developed a 5 axis CNC machine with Trivkins/Xyzac-trt permutation with activation codes M428/M430
Congrats!
I got a basic 5 axis to work and I may look into switchkins at some point.
- JackRay
- Thank you received: 14
I far from being a linux specialist, I was guided in my steps.
Good for now I am stuck, I can not open my linux seccion or is all my configuration. I don't know how to go about it.
- OT-CNC
- Thank you received: 7491
"Systemback" is the easiest to use and can make a backup of a running system, but do not forget to include the HOME folder to have all the stuff included, and convert to ISO.JackRay wrote:
I am looking to make a "bootable" image on an external USB drive.
If the resulting ISO does not boot but get only to a busybox, casper has to be removed and live-boot installed on that system.
- Thank you received: 2177
But I just made a big mistake. when I wanted to save my disk, an error happened. Now I can no longer open linuxMint, it tells me that my "login" is incorrect. I cannot access my session. I only have a "terminal" interface. I am desperate after all this time.
Can't help you much there, I'm afraid. But maybe try to explain what you were trying to do and what kind of error occured.
- JackRay
It's good, I was able to put everything back in the state, everything works correctly, I just have to machine.
Thanks again.
I will test the backups on another PC ...
