- Thank you received: 14
5Axis Kinetic from 2.8 on 2.7x
- JackRay
6 years 2 weeks ago #186005
by JackRay
Replied by JackRay on topic 5Axis Kinetic from 2.8 on 2.7x
Hello ,
No, I made a block-by-block copy. I think I have a problem with my hard drive. This solution works well as long as keeps the same PC. Unable to install image on another PC. it does not work .
I have a question, has anyone in the community tried to make an image (bootable .iso file from version 2.9pre like it was done on version 2.8?
Thank you
Thank you
- Thank you received: 7491
6 years 2 weeks ago #186032
Replied by tommylight on topic 5Axis Kinetic from 2.8 on 2.7x
Yes till lately i did always make a bootable and installable image, not anymore since installing a new Linux Mint system with LinuxCNC and kernel takes about half an hour or less.
Use "Systemback" it has a nice GUI and works properly, after removing "casper" and installing "live-boot", it can also save the home folder so when you boot from the USB you get everything, documents and software included.
- JackRay
6 years 1 week ago #186479
by JackRay
- Thank you received: 2177
6 years 1 week ago #186481
Replied by Aciera on topic 5Axis Kinetic from 2.8 on 2.7x
It tells you "Unknown parameter 'sparm=identityfirst'".
Have you built the switchkins-branch?
Note that sparm=identityfirst is used in the switchkins-branch to get linuxcnc to start the config using the indentitiy kinematics.
If you are already using the switchkins-branch. Then maybe delete sparm=identityfirst and try again.
- JackRay
6 years 1 week ago #186593
by JackRay
6 years 1 week ago - 6 years 1 week ago #186595
So do you get the error when you try to start the 5axis-trt-kins simulation or only if you try to start your own machines config?
Have you set the environment correctly?
$ cd ~/linuxcnc-dev/src
$ source ../scripts/rip-environment
Do that and run the simulation
$ cd ../configs/sim/axis/vismach/5axis/table-rotary-tilting
$ linuxcnc xyzac-trt.ini
Last edit: 6 years 1 week ago by Aciera.
Time to create page: 0.139 seconds
