- Thank you received: 4153
[ Vfdmod ] An easy VFD control over MODBUS RTU
4 years 7 months ago #236747
Replied by rodw on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
I think it could be scaled in hal. Each gear has a defined ratio. I might write a custom component to do it but coding the GUI for the selection, I try and avoid. Maybe Lincurve would do it.
- Thank you received: 1480
4 years 7 months ago #236889
Replied by Todd Zuercher on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
It is very common for VFDs to read the input for spindle speed to one decimal point. For example, you'd have to input 3000, for the drive to see 300.0hz.
4 years 7 months ago #236902
I cheated though and hardcoded all of the ratios in the component.
Todd, thanks, Last night I wrote a component that lets me select the front belt and back belt and retrieve a scaling factor for the given belt combo based on some tacho data I collected earlier. Also paired it with an extension to the PYVCP panel. So I should be able to send the S command to the component which will scale it to correct Hz before sending it to the VFD.It is very common for VFDs to read the input for spindle speed to one decimal point. For example, you'd have to input 3000, for the drive to see 300.0hz.
4 years 7 months ago #236912
- Thank you received: 7491
4 years 7 months ago #236939
Replied by tommylight on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
Bus voltage = 5830.0 V ???
- akg1904
3 years 10 months ago - 3 years 10 months ago #258790
by akg1904
Replied by akg1904 on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
Hi aekhv,
I am using Delta MS 300 VFD and tried to follow your guide but I was not able to establish connection with my VFD.
I have attached my INI and manual. It would very helpful if you could help me regarding the same.
Last edit: 3 years 10 months ago by akg1904. Reason: To attach files
Time to create page: 0.248 seconds
