Schaublin 125-CNC retrofit.
4 years 2 months ago #250612 by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
LMAO!
I doubt this drive will be reliable. It wouldn't boot for about 3 days, but now seems normal.
4 years 1 month ago #252567 by arvidb
Replied by arvidb on topic Schaublin 125-CNC retrofit.
CONGRATULATIONS on first chips! :D
4 years 2 weeks ago - 4 years 2 weeks ago #253969 by RotarySMP
Edit: I forgot to include the last video:
The Schaublin has the two hall sensors on the X axis, so it has the second config shown in the LinixCNC homing guide:
The +X limit switch will also be used as the home switch. I am a little confused by the HAL on this axis:
# ---setup home / limit switch signals---
#net x-home-sw       =>  joint.0.home-sw-in    [HMOT](CARD0).7i84.0.0.input-00 - (No separate home switch)
net x-neg-limit     =>  joint.0.neg-lim-sw-in [HMOT](CARD0).7i84.0.0.input-01
net x-pos-limit     =>  joint.0.pos-lim-sw-in [HMOT](CARD0).7i84.0.0.input-00
in combination with the INI:
[JOINT_0]
TYPE = LINEAR
HOME = 180
HOME_SEARCH_VEL = 2
HOME_LATCH_VEL = 2
HOME_FINAL_VEL = 2
HOME_USE_INDEX = YES
HOME_IGNORE_LIMITS = YES
HOME_OFFSET = 180
HOME_SEQUENCE = 0
Do I need the HOME_IS _SHARED to inform it that the switch it needs is the limit switch, or is that used for home switch pin shared between multiple axis? I guess my question is "how do I net the limit switch to also be used as the home switch?"
Mark
Last edit: 4 years 2 weeks ago by RotarySMP.
The following user(s) said Thank You: Masiwood123
4 years 2 weeks ago #253991 by smc.collins
Replied by smc.collins on topic Schaublin 125-CNC retrofit.
The odd thing about a lathe versus is a mill, In a lathe we want home to be as far from the chuck as possible typically so full travel to + Z and positive X. So in this case it is home to limit, and then IIRC you set home direction to positive.
So positive home can be a shared limit switch. it is the exact opposite of a mill typically.
in the Axis setup tab in pnconf, there is a direction for Home, and you can just set the travel direction towards the  + switch as the home switch, and then set the Z min " at chuck as the Z limit. I hope that's less confusing.
4 years 2 weeks ago #254005 by RotarySMP
THanks, I think i wasn't clear, as the direction of homing is not the issue, it is simply how to net to both joint pins. Thinking about it, I guess I just need to net the input pin to both joint pins:
net  x-pos-limit    [HMOT](CARD0).7i84.0.0.input-00        joint.0.pos-lim-sw-in        joint.0.home-sw-in
I will try that tonight. I sometimes get confused by the signals PNFconf creates.  I made the mistake of trying:
Which of course errors out with the pin already assigned error.
I already have Z working, as it has no limit switches, just the home. I am thinking of adding addition limit switches though.
Mark
4 years 2 weeks ago #254006 by arvidb
I tend to write my hal files as one input or output per line. I also tend to keep all connections to a certain net grouped together whenever practical. So something like this:
net x-pos-limit <= [HMOT](CARD0).7i84.0.0.input-00 net x-pos-limit => joint.0.home-sw-in net x-pos-limit => joint.0.pos-lim-sw-in
It's a bit lengthy but very clear IMO. It makes it very easy to see if a net has no, or several, inputs (i.e. an error) and it becomes very easy to add or remove a single connection.
Moderators: piasdom
Time to create page: 1.189 seconds
