Schaublin 125-CNC retrofit.
- RotarySMP
- Thank you received: 595
12 Oct 2022 08:45 - 12 Oct 2022 08:54 #254007
by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Thanks that is very clear. I guess I just got confused as there was one half created by PNFConf.
Another thing, limit switches. It should be pretty easy to add some to Z, ,but I will not be able to shield them very well. Would you guys tend toward microswitches or inductive prox sensors in the high swarf environment?
Mark
Mark
Last edit: 12 Oct 2022 08:54 by RotarySMP.
- smc.collins
- Thank you received: 139
13 Oct 2022 04:34 #254055
by smc.collins
Replied by smc.collins on topic Schaublin 125-CNC retrofit.
microswitches should be the easiest, and the cards you have from mesa will need to see a 70% change in voltage to trigger the event so if it's held low, at 0v, the switch will need to make at least 17v for the card to recognize it.
i wouldn't worry about no8se in a limit switch circuit, just make sure it's not parallel to a AC line that can induce voltage. should be fine otherwise, and if you have to run alongside a AC supply, just twist the wire like 10 turns per 50mm
- RotarySMP
13 Oct 2022 11:21 #254064
by RotarySMP
Thanks for the feedback on that. I will see if I can fit industrial end switches and an adjustment rail under the back of the saddle.
- smc.collins
13 Oct 2022 12:55 #254071
by smc.collins
- RotarySMP
13 Oct 2022 16:19 #254075
by RotarySMP
Thanks for the tip.
- spumco
- Thank you received: 896
14 Oct 2022 02:45 #254095
by spumco
Replied by spumco on topic Schaublin 125-CNC retrofit.
Speaking of tips...
If you want to replace the custom-molded axis hall sensors on the lathe, I'd suggest taking a look at air cylinder piston sensors. I've seen (and have) some really tiny proxys, reed, and hall switches that would probably fit in the cramped space. A silicone casting of the existing sensor heads and you could then cast some replacements with the same unique shape. Put the new switch in the mold and fill it with epoxy - you've now got a custom-fit limit/home switch.
If you go with inductive proxys instead of halls, you can remove the brass plug and magnet targets from the saddle and replace with a plastic plug - preferably UHMW or some other non-swelling flavor of plastic.
Maybe even spring for shielded cables if you're worried about noise... But your 24vdc system with NC sensors should be pretty resistant to that gremlin.
BTW, your existing sensor cable jackets appear have the same coolant-induced brittleness I've seen on older switches with PVC insulation. They looked stiff as a board in the vids
- smc.collins
15 Oct 2022 23:10 - 16 Oct 2022 14:55 #254197
by smc.collins
I was looking at my machine today the Cincinnati, and I have to be careful how it homes, because my tool carousel has a lot of stick out. so in my case I will home positive and use the index in the encoder. It will however require a very accurate stop switch and the indexing pulse to make it reliable and the base measurements of the machine need to be accurate as well
saw todays video, looking good man ! looks like you got the switches figured out ! most excellent.
Last edit: 16 Oct 2022 14:55 by smc.collins.
- RotarySMP
16 Oct 2022 20:58 #254259
by RotarySMP
This is the video...
The following user(s) said Thank You: tommylight, spumco, smc.collins
- Ausschuss-Manufaktur
- Thank you received: 10
18 Oct 2022 09:22 #254385
by Ausschuss-Manufaktur
Replied by Ausschuss-Manufaktur on topic Schaublin 125-CNC retrofit.
Great video as always!
Nice to see your 125 make some chips
Mine ist still in a cleaning and puzzling stage.
I have about the same wear in the ways as your machine has. (10-15 micron)
I also disassembled and cleaned the Ballscrews.
They are really easy to reassemble. If you ever feel the need to do so
I did not plan to put limit switches on my machine. Looking forward to your plans.
Lorenz
Lorenz
- Thank you received: 7468
21 Oct 2022 22:22 #254736
Replied by tommylight on topic Schaublin 125-CNC retrofit.
Pretty sure this will make you happy as i am fairly sure you did not see it lately and i know you were following it from the start, enjoy:
forum.linuxcnc.org/show-your-stuff/32784...ofit?start=60#254728
P.S.
Did not want to link to videos here as not to hijack your topic.
Thank you.
P.S.
Thank you.
Moderators: piasdom
Time to create page: 0.160 seconds
