Schaublin 125-CNC retrofit.
19 May 2022 13:46 #243341
I am a bit puzzled as to who this Gamet is. Gamet was a bearing manufacturer in Colchester, though I think that they have now been absorbed into Colchester lathes, moved to the Harrison works in Heckmondwike and now, apparently, based in Elland.
There is also an Indian chuck manufacturer called "Gamets" - www.gametschucks.com Which I suspect are unrelated...
I see references to "Pratt-Burnerd Gamet chuck" on that eBay, so I think that you probably need to be talking to the 600 group. www.colchester.co.uk/spares/
Replied by andypugh on topic Schaublin 125-CNC retrofit.
Which Gamet?. I contacted Gamet, with this unique business proposition, but they havent responded
19 May 2022 14:21 #243343
Hmm, but, also, I see Gamet boring heads, made in France..
And it seems that Gamet bearings are now part of HB bearings, in Holmfirth.
www.hb-bearings.com/
19 May 2022 14:24 #243345
And this might, finally, be the right Gamet: www.gam-tek.com/produits/Hmm, but, also, I see Gamet boring heads, made in France..
- RotarySMP
- Thank you received: 595
22 May 2022 10:24 #243544
by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Hi Andy, correct, it is Gamet in France who made, makes and still supports the power chuck business. No idea if they were ever associated with Gamet the bearing manufacturer.
Mark
Mark
23 May 2022 12:19 #243607
It seems likely: www.gracesguide.co.uk/L._Gamet_Products
So, started off in France.
The patent makes interesting reading: patents.google.com/patent/US2499640
- RotarySMP
05 Jun 2022 10:02 - 05 Jun 2022 11:07 #244606
by RotarySMP
Made some decent progress on the reassembly...
Last edit: 05 Jun 2022 11:07 by RotarySMP.
The following user(s) said Thank You: arvidb, tommylight, Muzzer, anfänger, spumco, CarterKraft
- arvidb
- Thank you received: 158
08 Jun 2022 01:46 #244745
by arvidb
Replied by arvidb on topic Schaublin 125-CNC retrofit.
Nice work! Good catch that you had to prime the pump. I would have had no idea why it didn't work.
I have no real experience with these things, but if it was my beautiful Schaublin I would remove the motor and turn the screw by hand through its full range of motion to feel that everything was alright before applying the full motor torque.
- RotarySMP
12 Jun 2022 11:05 - 12 Jun 2022 11:06 #244984
by RotarySMP
Good idea. I need to do that.
a few minor steps this week:
Last edit: 12 Jun 2022 11:06 by RotarySMP.
The following user(s) said Thank You: arvidb, tommylight, anfänger
- RotarySMP
10 Jul 2022 10:15 #247000
by RotarySMP
I dont get it, I have Hall sensors outputting a 4V "High" signal into a 7i84 with the Field voltage set at 5V for that bank, but am not getting a LO-->HI transition in the HALshow. The 7i84 should go high above about 2.6V or so.
Any troubleshooting advice appreciated.
The following user(s) said Thank You: anfänger
- Thank you received: 7490
10 Jul 2022 10:42 #247004
Replied by tommylight on topic Schaublin 125-CNC retrofit.
What type of hal sensor?
What output does it have?
Might need a resistor as pull up or pull down.
Some give variable voltage on the output depending on magnetic field.
Moderators: piasdom
