- Thank you received: 595
Schaublin 125-CNC retrofit.
- RotarySMP
3 years 10 months ago #259199
by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
I need some help here guys please. I can't get my drives well tuned. Wout did a couple of calls with me to help me out, which has led me to a better understand the problem.
I am running JMC drives in analog mode.
There are some good videos out there on how to tune them in step/dir, but it seems no one else is using these in analog mode. There is a software provided by JMC to assist in tuning, which has a built in oscilloscope. This brings me to my problem:
The JMC software offers only a limited number of parameters you can select to graph on the osci. The selection more limited in analog mode. In step/dir you can graph the following error. In analog mode you can't. There appears to be no parameter which I can graph which displays the following error in analog mode. I contacted JMC, and they came straight back with "what is FError?", and when I explained I need a following error value, they have not replied since.
At one level, I can graph following error in LinuxCNC, but then I am limited to the 1kHz servo thread. It appears that the internal torque/velocity loops are closed in the JMC driver at 6kHz. The guidance I got from Wout is that I need to tune that higher frequency control loop first, before trying to tune the LCNC loop wrapped around it.
The best idea I can come up with to tune the JMC's torque/velocity loop, would be to make up a cable, temporarily set up a single axis of step/dir open loop control from LinuxCNC to the JMC driver/servo system in position mode, and one at a time tune my drives for the reflected inertia. Only once the drives are tuned on open loop STEP/Dir position mode, then I can reconnect them to the current INI, switch them to analog mode, keeping the same tuning setting internally, and tune the LinuxCNC position loop at 1kHz using the LCNC Halscope.
Or is this a dumb idea? If I understand the cringlisch manual (I really understand much of it), it would seem that the internal values for certain parameters are simply ignored in analog mode, but that the others would be retained as tuned.
To do this, I would need a channel of Step/Dir. I am running MESA 7i92 -P2-> 7i85, then SS to 7i83, 7i84, 7i73 on this machine. It looks like I will need to flash my 7i92 with the G540X2D bitfile to activate stepgens, and then wire into P2.
Is there an easier way of doing this, where I don't have to upset my existing wiring by removing the 7i85? So I could access a Stepgen on P1, the 26 pin header of the 7i92?
I would appreciate any suggestions you have. If my whole idea is crap, and there is a better way of doing this, I am all ears.
Thanks,
Mark
ps. I still haven't gotten back to the Lathe macro installation. I dicked around with a couple of other things for the last couple of weeks, as my videos show
Thanks,
Mark
- spumco
- Thank you received: 905
3 years 10 months ago #259202
by spumco
Replied by spumco on topic Schaublin 125-CNC retrofit.
Mark,
Not a drive tuning expert, but is there a function in the JMC software that allows you to directly run the motors (i.e. through RS-232 or 485)? Might be able to tune the internal loop that way and not have to rig up a temporary S&D config through LCNC.
Switch the drive to S&D mode so you can see the internal FError (but command via JMC software), tune internally, then switch to analog and do the outer LCNC loop...? Just spitballing here.
-Ralph
-Ralph
3 years 10 months ago #259204
Replied by andypugh on topic Schaublin 125-CNC retrofit.
Maybe you can set up a very simple config using on a Mesa encoder to measure the position and a siggen to create a command signal, and run that in a 6kHz thread?
- smc.collins
- Thank you received: 139
3 years 10 months ago #259205
by smc.collins
Replied by smc.collins on topic Schaublin 125-CNC retrofit.
graph servo analog out in hal scope, open the calibration feature in axis etc. turn the P setting to zero , set ff1 to 1 make sure the other ff settings are zero.
there 2 potential issues, 1 is gain is to high or low " most likely culprit" or the servo dampening is wrong, usually excessive from my experience. I'd suggest turning down the servo dampening to nearly ZERO, if you start to see oscillation in the motor, turn it back up, that is with ZERO commanded voltage from the mesa card and servo output and the motor in a holding position. Now, put a slight load on the servo motor until it can fight back and hold position.
I assume your encoders go directly to your drives, so I doubt this is a tach gain issue.
once you get your dampening settled, no oscillation even when holding TQ with the drive enabled with zero voltage commanded, connect the spindle servo out from the mesa card again, and start tuning gain. use the jog function to traverse the drive with the carriage load on it. you should see nice square signal edges in your hal scope trace, if you don't, here's where to start. If you sea big spike on the left of the trace, then it ramps down and slowly levels off, the gain is to low, if you see a big oscillation and a ramp trending up, left to right, the gain is to high. I'd start at say 30 ipm, and jog, aggresively, then bump to 50ipm, then 100 ipm etc, each time matching the gain so that the drive output voltage looks like a nice sharp square tooth on both edges with a flat Vout once the acceleration is completed. The accel curve obviously will vary with each drive etc, but I'd expect to see a nice 45-80* climb up and down, near vertical to the held motion voltage.
while not your drive, they do have a section about adjusting gain and compensation. and the patterns of response are representative of the behavior you need to see from the servo Vout from linuxCNC. I got my drives for 600 ipm using this method, with old brushed DC permanent magnet motors. YMMV
www.glentek.com/download/smb7230-smb7275-smb72100-rev-c-manual/
- RotarySMP
3 years 10 months ago #259209
by RotarySMP
There should be a way to have it jog back and forwards from within the drive. I tried to program that, bit could not get it to work. That would have been the easiest solution by far. Thanks for reminding me, I will try contacting JMC again, and ask about that function.
- RotarySMP
3 years 10 months ago #259210
by RotarySMP
Thanks for that. You packed a lot of info in there. I will try this first, and see if I can follow it all.
The following user(s) said Thank You: smc.collins
Moderators: piasdom
Time to create page: 0.859 seconds
