Configuration 7i92 and 7i77 - get error
5 years 9 months ago #197075 by PCW
Replied by PCW on topic Configuration 7i92 and 7i77 - get error
I suspect you are using non-dpll firmware
what does:
mesaflash --device 7i92 --addr 10.10.10.10 -- readhmid
report?
5 years 9 months ago - 5 years 9 months ago #197080 by PCW
Michael wrote: I am 99% sure I also don't have that and have been # out setp hm2_7i92.0.stepgen.timer-number 1 since it was creating errors. That could explain my 5ms delay from encoder response, or part of it.
No, adding DPLL retiming will make the average delay between reading the encoders and writing the analog out
slightly longer (by 50 usec in the example)
It's expected that "setp hm2_7i92.0.stepgen.timer-number 1" would cause an error if you
dont have any step generators in your configuration. This is presumably a pncconf bug.
Last edit: 5 years 9 months ago by PCW.
5 years 9 months ago - 5 years 9 months ago #197082 by bevins
Replied by bevins on topic Configuration 7i92 and 7i77 - get error
PCW wrote: I suspect you are using non-dpll firmware
what does:
report?
DPLL module is there
Warning: Spoiler!
Last edit: 5 years 9 months ago by bevins.
5 years 9 months ago #197091 by PCW
OK well that's fairly mysterious, I just built 2.8.1 and the pin is there:
7 s32 IN -1 hm2_7i92.0.encoder.timer-number
I had been checking with master but 2.8.1 works for me
Can you check the bitfile checksum?
$ md5sum 7i92_7i77_7i74D.bit
9adaf5281f07f798d9fa87580f63e6c2 7i92_7i77_7i74D.bit
5 years 9 months ago - 5 years 9 months ago #197095 by bevins
PCW wrote: OK well that's fairly mysterious, I just built 2.8.1 and the pin is there:
Ill check it after supper but i got the 7i92 zip file from freeby.mesanet site. I compiled mesaflash from github and got the 7i92.zip from your site.
Maybe the zip file dont have the correct files in it? Can you send the bit and pin files?
5 years 9 months ago #197096 by bevins
Thats bizarre. The checksum works out.
Is it a config on the loadrt line?
Moderators: PCW, jmelson
Time to create page: 0.309 seconds
