Configuration 7i92 and 7i77 - get error
5 years 8 months ago - 5 years 8 months ago #197556 by PCW
Replied by PCW on topic Configuration 7i92 and 7i77 - get error
aleksamc wrote: I have also problem with connecting MPG to 7i77.
I used example
I connected MPG to encoder.03.count and I have change of this imput.
joint.0.jog-scale is not zero joint.0.jog-enable is TRUE axis.0.jog-counts is changing sucsesfully
But axis i not moving.
I use PyQtvcp interface.
What problem could be in?
That would be expected if the system was not homed, you would have change
the joint.0.jog-counts before homing and axis.0.jog-counts after homing.
(jogging before homing is a bit dangerous since no soft limits have been established)
Last edit: 5 years 8 months ago by PCW.
The following user(s) said Thank You: aleksamc
5 years 8 months ago #197561 by aleksamc
Replied by aleksamc on topic Configuration 7i92 and 7i77 - get error
Thanks PCW, you've solved both my problems.
Before your answer I made thought about difference between jog and axis. But I work now in so noizy conditions, that I tried axis.a instead axis.x)))
5 years 8 months ago - 5 years 8 months ago #197619 by aleksamc
I'm alsmost everything configured in hal.
But yesterday I gor comunication error 2 times.
Second time was at the end of the day when machine was stopped (not moved but turned off).
I have
setp "hm2_7i92.0.watchdog.timeout_ns 2000000"
Errors are
"smart Serial Card ... Local Error ... Timeout"
I must say that I use very short Ethernet cable, less then 0,5m.
Also this cable is shielded to machine GND that is Neutral.
Possibly, it's better to shield to 0V of DC current?
But I don't think that problem could be in this. 4 years ago I used 7i92m board to make comunication with PC on 25m length of Cable and there is no Problem with communication. But there watchdog is set to 5 000 000.
Last edit: 5 years 8 months ago by aleksamc.
5 years 8 months ago #197620 by PCW
That looks like more of a real time issue than a sserial issue
What was the first error?
Starting LinuxCNC from the command line would probably help
when debugging since all the errors will be logged there and can be copy-pasted
here
5 years 8 months ago - 5 years 8 months ago #200030 by aleksamc
PCW wrote: That looks like more of a real time issue than a sserial issue
here
Today I've got such error one more time. I attach copy of terminal output in the file.
File Name: error2.txt
File Size:13 KB
I increased watchdog parameter to 5000000. I have default SERVO_PERIOD = 1000000
But I got today another trouble. My one servo drive turns off and doesn't give any sign of life.
It's CACR-SR10BE12G-E yaskawa. I found that on back side is apcent cooling fan. I hope it doesn't overheet. It seems that some fuse in control circuits blowup. I took it home in will look tomorrow what inside.
I make refit of old CNC it's on configuration state. It worked 5-10 minutes.
5 years 8 months ago #200037 by PCW
If you get a watchdog bit error like that, it means you have lost communication
for many cycles.
I would take a look at the tmax parameters after an hour or so of operation
halcmd show param *.tmax
Moderators: PCW, jmelson
Time to create page: 0.324 seconds
