- Thank you received: 59
Configuration 7i92 and 7i77 - get error
- Michael
hm2_7i92.0.encoder.timer-number 1
Would this create encoder timing issues?
- Thank you received: 5334
7 s32 IN -1 hm2_7i92.0.encoder.timer-number
What LinuxCNC version are you running?
Michael wrote: Whats the relevance of this line?
setp hm2_7i92.0.dpll.01.timer-us -50
setp hm2_7i92.0.encoder.timer-number 1
Will enable DPLL sampling of the encoder position
rather than raw sampling. This reduces the sampling
jitter from as much as a few hundred usec to 250 ns
or so.
The first statement sets DPLL timer 1's sample
time to 50 usec _before_ the nominal read time.
The next statement tells the encoder hardware
to use DPLL encoder sampling rather than
raw sampling (the default timer number of -1
selects raw sampling)
- Michael
- bevins
- Thank you received: 338
PCW wrote: Just loaded 7i92_7i77_7i74D firmware and I get:
I am running 2.8.1-44
- bevins
Pin List for encoders:
