- Thank you received: 5334
Configuration 7i92 and 7i77 - get error
5 years 9 months ago #197097
Replied by PCW on topic Configuration 7i92 and 7i77 - get error
Not unless the config line disabled the DPLL
- aleksamc
- Thank you received: 67
5 years 9 months ago - 5 years 9 months ago #197110
by aleksamc
Replied by aleksamc on topic Configuration 7i92 and 7i77 - get error
I changed stepgen to encoder:
and graphical interface starts.
But I get another error:
I use Intel J1900 fanless PC.
In BIOS I previously disablem all parameters that could make delay and also made isolcpu=2,3 that gives me very good latency (10k to 15k).
hm2_7i92.0.encoder.timer-number
hm2_7i92.9: Watchdog has bit! (set the has-bit to False to resume)
hm2_7i92.0: Error after doit clean
Last edit: 5 years 9 months ago by aleksamc.
5 years 9 months ago #197111
Do you have all power management turned off? (no C states > C1)
idle=poll in the kernel command line helps also (set with grub)
What are you ping times to the 7I92?
- aleksamc
5 years 9 months ago - 5 years 9 months ago #197114
by aleksamc
I will look for ping today I think, also I will add to ethernet interface settings
"hardware−irq−coalesce−rx−usecs 0" as in the hm2_eth manual
Now I read this manual for some additional help.
Also ethernet cable is very short, less than half of meter. And it also shielded to the ground. Phisicaly, ground is neutraled.
Power management, it disabled complitly in BIOS. I had very big latency delays when I bought this PC, more then 300k. After disabpling a lot of parameters in BIOS I got 30k. And after setting isolcpu=2,3, I got 15k and less.
PCW, I didn't understood, what does it mean "idle=poll", where to set it?
Also, how to disable IPV6, if I have it?
- Thank you received: 7491
5 years 9 months ago #197139
Replied by tommylight on topic Configuration 7i92 and 7i77 - get error
Idle=poll goes before or after the isolcpu in grub.
- aleksamc
5 years 9 months ago - 5 years 9 months ago #197302
by aleksamc
I've check ping to mesa board and I got
In hal I increased watchdog time to 1300 000 (I thing I don't make here any mistake in zeros).
And it seems, everithing work fine.
Now I start to run servos and I wonder, I've connected them to ENA pins of mesa 7i77 board (it's near analog output). What HAL pin controls this pin? Where it's written in my hal address of this pin?
rtt min/avg/max/mdev = 0.187/0.287/1.354/0.129 ms
Time to create page: 1.475 seconds
