- Thank you received: 67
Configuration 7i92 and 7i77 - get error
- aleksamc
5 years 9 months ago #197304
by aleksamc
Replied by aleksamc on topic Configuration 7i92 and 7i77 - get error
After turning on I laso received remote error from 7i77 as (27) Over Current.
I don't understand why, I've connected only one relay. I use 7i77D
- Thank you received: 5334
5 years 9 months ago #197305
1.354 ms is pretty bad...
The first 5 analog enables (0 through 4) are controlled by the analogena pin
If you have an overcurrent warning, you may have the relay miswired
(flyback diode backwards?) or too large a relay without a flyback
Replied by PCW on topic Configuration 7i92 and 7i77 - get error
rtt min/avg/max/mdev = 0.187/0.287/1.354/0.129 ms
Now I start to run servos and I wonder, I've connected them to ENA pins of mesa 7i77 board (it's near analog output). What HAL pin controls this pin? Where it's written in my hal address of this pin?
- aleksamc
5 years 9 months ago #197307
by aleksamc
I have flyback diods, maybe relays are a bit large, I will look.
What current should be on one output of the board?
5 years 9 months ago #197309
350 ma is max
Are you sure your flyback diodes point the right way?
On a 7I77D:
+12/+24V to relay_coil-1 + diode cathode (band)
7I77D-Output to relay_coill-2 + diode anode
On a 7I77D:
- aleksamc
5 years 8 months ago #197313
by aleksamc
Yes, for diod connection I'm sure.
Relays are something bigger than I used previously. They are from refitting machine, they need 387mA.
Will they work? I think I need only 6 such relays.
- aleksamc
5 years 8 months ago #197385
by aleksamc
I want to clearify, I need to write it in the same line as isolcpus, like this
<<<<.... = "isolcpus =2,3 idle=pool " >>>>?
tommylight wrote: Idle=poll goes before or after the isolcpu in grub.
Time to create page: 0.946 seconds
