- Thank you received: 5334
Differential encoder hard crashes the PC MESA7i77
7 months 5 days ago #344835
Replied by PCW on topic Differential encoder hard crashes the PC MESA7i77
Yes, you need to install firmware that matches the 7I77
You first need to download the 5i25.zip from
www.mesanet.com/software/parallel/5i25.zip
unzip and then change to the configs/hostmot2 directory and then
sudo mesaflash --device 5i25 --write 5i25_7i77x2.bit --reload
- grossm5000
7 months 5 days ago #344836
by grossm5000
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
- grossm5000
7 months 5 days ago #344837
by grossm5000
7 months 4 days ago #344844
Did you try running mesaflash after running LinuxCNC?
- grossm5000
7 months 4 days ago #344845
by grossm5000
7 months 4 days ago #344851
Can you do a
lspci -vv | grep -A 10 2718 > pci.txt
and post pci,txt here?
The following user(s) said Thank You: grossm5000
