Differential encoder hard crashes the PC MESA7i77
7 months 4 days ago #344855 by grossm5000
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
Here we are! I super appreciate it...so does my wife   Ive been trying to make this work all day
7 months 4 days ago #344857 by PCW
The problem is this:
Region 0: Memory at fce00000 (32-bit, non-prefetchable) [disabled] [size=64K]
Which is likely something the BIOS did so may be fixable if you have access to BIOS PCI settings
I will take a look into what is needed to get mesaflash to re-enable the memory region (lLinuxCNC does this)
The following user(s) said Thank You: grossm5000
7 months 4 days ago - 7 months 4 days ago #344858 by grossm5000
I do have access to some BIOS PCI settings, but not sure if I can screenshot them. I am afraid the best I can do is take a picture.
I did some searching...will this command do anything for me?
sudo setpci -s 04:00.0 COMMAND=0x02 supposedly enables the memory space, but I am certainly not a software wizard...
Last edit: 7 months 4 days ago by grossm5000.
7 months 4 days ago #344859 by grossm5000
the options in my BIOS PCI Subsystem Settings are:
Above 4G Decoding (enable/disable)
SR-10V Support (enable/disable)
and in BIOS Onboard Device Configuration
PCIEX1_1 Mode (auto) <--but i think this only refers to speed. I have this selection/option for all the PCI slots on the board
I tinkered with all of these earlier today to no result. I do have an ASUS A520M motherboard...BIOS options seem pretty generic.
7 months 4 days ago - 7 months 4 days ago #344860 by PCW
You could try  setpci and verify if the [disabled] goes away from the lspci listing
Last edit: 7 months 4 days ago by PCW.
  • Moderator
  • Moderator
7 months 4 days ago #344863 by tommylight
Replied by tommylight on topic Differential encoder hard crashes the PC MESA7i77
See if you can disable this in BIOS, it is usually enabled by default
www.google.com/search?client=firefox-b-l...ssive+power+managent
Also, if you are using any kind of PCI-E riser or cable, se the PCI-E speed/mode to GEN1
Moderators: PCW, jmelson
Time to create page: 0.418 seconds
