Differential encoder hard crashes the PC MESA7i77
- grossm5000
7 months 1 week ago #344516
by grossm5000
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
I am wondering if my PCIe slot is bad. Trying a different slot today…stay tuned…
- Thank you received: 5334
7 months 1 week ago #344525
Replied by PCW on topic Differential encoder hard crashes the PC MESA7i77
lspci did find the card but mesaflash does not, that may indicate a bad 6I25
There are no LEDs illuminated on a 6I25 in normal use except very briefly at power on.
- Thank you received: 7491
7 months 1 week ago #344527
Replied by tommylight on topic Differential encoder hard crashes the PC MESA7i77
Disconnect the 7i77 from 6i25, check if MesaFlash finds it.
- grossm5000
7 months 1 week ago #344528
by grossm5000
OK, disconnected the 7i77 from the 6i25. ran mesaflash, linux couldn't find the board.
Am I needing a new 6i25? I ordered this AM on the hunch I probably would...
In other news, if I launch linuxCNC with the 7i77 removed from the 6i25, my PC doesnt hard crash anymore, just gives the following error:
I have the report from that if it means anything.
All of the above was done on a new (different) PCIe slot...so the slot being a problem should be removed as a potential issue
7 months 1 week ago #344539
Well, LinuxCNC found the card so it does not seem to be an issue
with the PCIE slot or the 6I25 bus interface.
What is the actual error when you have the 7I77 connected?
The following user(s) said Thank You: grossm5000
- grossm5000
7 months 5 days ago - 7 months 5 days ago #344829
by grossm5000
HEY! I am so dumb I didn't see your reply till just now. I actually bought another 6i25 convinced I had an issue with the card.
ANYWAY...I don't get any errors when I launch LinuxCNC, just a hard, full computer shutdown if the 7i77 is connected to the 6i25. If the 6i25 is NOT connected to the 7i77, I just get the Linuxcnc error i posted earlier.
So...I put in the NEW 6i25 just now, hooked up the 7i77 and launched Linuxcnc...and it DIDNT CRASH this time! Exciting. Now i just get a new Linuxcnc error:
Looks like the firmware wants an update? Do I do this with mesaflash?
Last edit: 7 months 5 days ago by grossm5000. Reason: added more information after trying new 6i25 card
Time to create page: 0.458 seconds
