Differential encoder hard crashes the PC MESA7i77
- grossm5000
7 months 22 hours ago #345009
by grossm5000
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
- grossm5000
5 months 5 days ago #346677
by grossm5000
OK guys,
Finally back on this again. Got LinuxCNC stable, ended up being a failing hard drive issue. Got my 6i25 and 7i77 boards back from MESA, everything checked out ok.
I am still struggling on the MPGs. Still crashes the computer when I scroll the MPG handwheel. Its a differential encoder, plugged into encoder #3 slot on the 7i77. I have tried a new MPG, same result. I would say its safe to say the MPG hardware is not the issue.
- Thank you received: 5334
5 months 5 days ago #346678
Replied by PCW on topic Differential encoder hard crashes the PC MESA7i77
Can you power the 7I77 from an external 5V supply?
When you say crash, what actually happens?
- grossm5000
5 months 5 days ago - 5 months 5 days ago #346679
by grossm5000
When I say crash, I mean the computer shuts down and reboots.
The 7i77 is powered by an external 5vdc supply. Here are some pictures of the wiring
I am getting 5vdc between the screw labeled vcc and 0vdc. Interestingly, I can start LinuxCNC with the encoder hooked up and it will not crash unless I move the hand wheel. I used halshow to verify other buttons are working (joystick, start, stop, etc.)
power supply for 7i77 is 15w/2.4 amp
Last edit: 5 months 5 days ago by grossm5000. Reason: Add power supply detail
5 months 5 days ago #346680
OK that sounds more like a hal issue or maybe hardware (Memory?) issues on the PC
Can you post your hal/ini files?
The following user(s) said Thank You: grossm5000
- grossm5000
5 months 5 days ago #346681
by grossm5000
here are my hal and ini files. I only have a few buttons working at the moment so it should be pretty generic so far
Time to create page: 0.898 seconds
