Brother TC-211
21 Jun 2014 17:21 #48162 by BigJohnT
Replied by BigJohnT on topic Brother TC-211
Here is my plans for a RPC, they are pretty simple to build. I did find over the years that a motor designed for a RPC gave more balanced voltage between phases. I found North American Phase Converters to be very helpful and after many years of using old 3-phase motors I purchased a motor from them.
gnipsel.com/shop/rpc/rpc.xhtml
JT
22 Jun 2014 01:19 #48170 by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
I saw your plans and they are very well written. Only thing is I am not good at schematics. I have a wiring diagram, showing the components, and hook up points on them all really dumbed down.
01 Jul 2014 07:18 - 01 Jul 2014 07:33 #48350 by mblaszkiewicz
Ok machine is powered and running with the brother controller. Time to o the conversion. Thanks to pcw. I have the 7i77 card. Now I have a bunch of questions. I have a pic of the servo drivers. x,y and z are the same. Looks like the CN8 connectors are for all communication to the processor (I traced them back red white and blue wires). If I could get some advice on how to connect the drivers to the 7i77 card I would be appericative. The text pics are from my manual and describe the input/outputs. I'm just totally lost. Electronics are not my strong suit. So any help in appericated. especially PCW if you could chime in.
Last edit: 01 Jul 2014 07:33 by andypugh.
01 Jul 2014 07:26 #48351 by mblaszkiewicz
Ahhhhhhhh if someone can fix up the picture posts for me, and sorry they are upside down
01 Jul 2014 07:40 #48352 by mblaszkiewicz
Thanks andy :)
Someday I'll figure it out
01 Jul 2014 09:25 #48353 by PCW
Replied by PCW on topic Brother TC-211
A sharper version of the third drawing would help a lot
(so pinouts can be read)
Looks pretty standard and simple other than the torque limit option
01 Jul 2014 09:39 - 01 Jul 2014 09:49 #48354 by mblaszkiewicz
Here is the redo of page 3 It is at a much higher res.
and page 2 redo hi res
Last edit: 01 Jul 2014 09:49 by mblaszkiewicz. Reason: added another pic
01 Jul 2014 10:49 - 01 Jul 2014 10:52 #48356 by PCW
Here are representative connection guesses for X (channel 0)
DRIVE	        7I77
ENCODER
CN8-10   A      TB3-1
CN8-9    /A     TB3-2
CN8-12   B      TB3-4
CN8-11  /B      TB3-5
CN8-17   Z      TB3-7
CN8-13  /Z      TB3-8
ANALOG VELOCITY COMMAND
CN8-1  AOUT   TB5-4
CN8-2  GND   TB5-3
DRIVE ENABLE
CN8-15  ENA+    TB5-2
CN8-16  ENA-  TB5-1
I am making some assumptions here,
first assumption is that the start pin of the drive is not latched (its a drive enable)
The second assumption is that the current limit mode is not needed
Last edit: 01 Jul 2014 10:52 by PCW.
03 Jul 2014 06:33 #48405 by mblaszkiewicz
Well got back from the cable store. 115 for cabels, so this weekend its time to get the machine under linux control. Hope some of you are here for tech advice as needed.
03 Jul 2014 08:32 #48408 by andypugh
Replied by andypugh on topic Brother TC-211
115 for cabels,.
Eek! But then the connectors for my servos cost 2x what I paid for the three servos, so not such a surprise.
Time to create page: 0.269 seconds
