spent a week working on my rust bucket truck and had a little bit of time to sort out some CNC stuff for this brain storm this weekend
i was able to get into the spindle to see what was in there from the factory, the bore of the casting is straight through with a sleeve pressed in for the bearings. i think i can press the sleeve out and open up the bore on both ends to to make a new spindle shaft. i had built a BT 30 spindle in the past but i want to keep the casting since its part of the linear way assembly of the original grinder.
the first spindle i made turn out decent it had about .0002 of run out which i was fine with since i made it a little 10 x 21 lathe. the spindle shaft was not to bad to make since the biggest diameter was 2.750 inches, the only thing i would change would be the bearing OD since the casting is a little bit smaller then what i did for a housing on the first one. the first one had 45 x 85 x 16 mm bearings but i can get 45 x 75 x16 mm instead for this one. i think i had a bit of overkill on the first one anyways
but the idea is to keep the same design for the shaft and just modify the diameters for the bearings.
some pictures of the prototype spindle i made before. i was also working on some kind of way cover for the back side. i see to much chips falling down and creating problems but that is still a work in progress but i at least have a plan for it now and have stuff gathered up to make something for it
