- Thank you received: 312
The only reason to heat-treat would be for wear resistance. I do see some signs of fretting in my own spindle, as there is a lot of cyclic load variation.it's tough material and most of the uses for it are when you want to do away with the heat treating process but still need something tough.
You wouldn't, that's a UK web site and we don't (generally) use AISI steel grade codes.i did look at that site and i did not see 1144SP listed
Bearing fits, yes. I would certainly be looking to mask those. But the taper could change by a few tenths, leading to the seating depth of tools changing by a thou or so. Neither here nor there, the tools themselves vary more than that.from what i could gather this process does not have to much impact on sizes to a point but when you get into tenths it can change sizes. so with bearing fits and the spindle tapper you are into those kinds of tolerances.
