- Thank you received: 286
Whilst mesa and ethercat might coexist as they NIC they use are defined for each environment, the question is why do that?
Ethercat can do everything a mesa card can do and then some.
Understood. Earlier post was just a mild warning, not a hard THOU SHALT NOT sort of thing.k, running my tool mag properties through yaskawas calculator to figure out inertia. you do quickly get out of range, but the 40mm 50w will be fine as long as i take some time accelerating. 1-2 seconds to get up to speed.
This doesnt need to be high performance, just for function testing.
