Mini wannabe datron build
2 years 3 months ago #305420 by rodw
Replied by rodw on topic Mini wannabe datron build
1-2 secs accel sounds pretty terrible. This is where the low down torque of a stepper shines. I can get a plasma cutter to 10 m/min in 170 milliseconds with steppers.
This is not a CNC application but more of an industrial design problem. The work energy method is applicable
www.machinedesign.com/motors-drives/arti...rs-for-linear-motion
Here they use a 33% motion profile. For CNC, we settled on 1% profile
This video of mine explains further.
www.loom.com/share/64ef8fb135ad47bcaf006...33-b18f-4d63f2718a1b
2 years 3 months ago #305421 by ihavenofish
I have step and direction ports available. But i need to test ethercat, so i thought it would be nice if i can mix and match for testing
2 years 3 months ago #305423 by ihavenofish
The stepper has LESS torque, and we are using only about 1% of that anyway. It will still change tool to the next pocket in about half a second....
So no issues with torque. The issue is inertia ratio. Ideally I would have a 4:1 reduction and then I could whip the thing around 180 in 100 milliseconds... but we don't have that option right now. So as a result we have a quite high inertia ration, but since we also have a very simplistic motion path it should manage at slow acceleration.
I want also direct drive for now to test the absolute encoders on the servo with no other systems to cause me issues (like belts or gears and bearing assemblies)
Using a stepper would defeat much of the point of this.
2 years 3 months ago #305441 by spumco
Replied by spumco on topic Mini wannabe datron build
Sounds like you've got a solid plan.  Can't wait to see it.
2 years 3 months ago #305533 by ihavenofish
thanks. Now i just need some monies to waste on this!
anyone wanna buy some used pizza crusts?
ATC placement on the v1 machine (functionally the same as my current prototype). It's barely bigger than the servo.
2 years 1 month ago #310031 by ihavenofish
Progress on the design. Refinements, Tweaks. I got some quotes from JLC for machining and it might be viable to make these for people one at a time, complete with bead blasted anodised finishing. Frame kit with screws and rails, but nothing electrical. Need to get all the prices to the penny and then I will see if one adventurous person would like one. :)
Time to create page: 0.162 seconds
